2002 with no Power at startup
Old Aug 3, 2011 | 10:44 AM
mattgreg's Avatar
Had this truck since new (only 49K miles) Has a Banks system on it, but doesn't ever get driven hard, but this morning I took off and for 100 yards I had absolutely no power, and white smoke. Couldn't shift out of 2. Then all of a sudden like a flip of a switch everything was back to normal. I'm kinda new here so any help would be appreciated. I've read about the VP44 issues, and know how much they cost and would like to head off any expensive repairs.
Old Aug 3, 2011 | 01:02 PM
rebal's Avatar
It could be a sign ,Did you check for codes? it could also be from sitting for a long time,My 01 does it every oncein awhile and its done it for the last 5 years , its rare but it happens. check for codes key off and on 3x leave in on pos. dont start read ODO for codes you will get Pdone when its through
Old Aug 3, 2011 | 02:09 PM
mattgreg's Avatar
Thanks, Comes up with P1693. Does anybody know what that is?
Old Aug 3, 2011 | 03:18 PM
RowJ's Avatar
That is a companion code.... means there is the same code in the ECM that is showing up in the PCM.....
There should be at least one other code?
I would check simpy things first, before jumping to a $1200
+ VP-44.
Fill in your signature to help us help you.
Mileage, Type Trans, any mods, etc
RJ
Old Aug 3, 2011 | 06:22 PM
mattgreg's Avatar
Thanks for the idea. I think I got it updated, but it is a 6sp instead of Auto. Truck has done this thing twice in the last month. Other than that it runs fine. Hate to sound like a newbie but what are the simple things and how can I rule out the ottomind banks tuner box?
Thanks
Matt
Old Aug 4, 2011 | 07:32 AM
j-fox's Avatar
Un hook it for several days to see if it still does it.
most likely you have a pump issue. What is the fuel pressure at the injection pump?
http://www.bluechipdiesel.com/vp44diagnostichelp.html
Old Aug 4, 2011 | 07:42 AM
mattgreg's Avatar
Thanks, Will do.
Old Aug 4, 2011 | 08:03 AM
RowJ's Avatar
I would go to Autozone, or somewhere with a professional scanner, and get a more complete readout on your codes.
RJ
Lockman
Nov 12, 2008 10:09 PM
markm4
Oct 10, 2007 11:09 PM
Lark
Feb 27, 2007 05:32 PM
CCOUGHRAN1
Sep 14, 2006 09:15 PM
TDon
Aug 8, 2006 04:30 PM
