2001 tranny problem
Old Oct 26, 2005 | 09:26 PM
puet's Avatar
2001 tranny problem
just bought the 01 ram 2500 w/ auto. the tranny doesnt shift right from 1st to 2nd. sometimes it's good, but then other times i'll have to get up to about 2800 rpms before it will shift to 2nd. just wondering what the edit i might be able to do to get it right.
Old Oct 26, 2005 | 09:43 PM
2500Ram's Avatar
Fluids good, color and smell. Check on level ground with engine running in Neutral with engine running, emergency brake on
Old Oct 27, 2005 | 05:33 AM
Rrloren's Avatar
About 2 months ago mine was doing the same thing then started locking into OD at very low speed and stalling the truck.
Turned out to be the speed sensor and a cheap fix. Shifts great now.
Old Oct 27, 2005 | 10:47 AM
puet's Avatar
tranny
yea, i've been reading up on other threads and i was thinking the same thing about the speed sensor. where is it and how difficult a job is it to change?
Old Oct 27, 2005 | 12:01 PM
67HotRod's Avatar
I would have a trans shop run a scanner on it before throwing money at it.
Old Oct 27, 2005 | 12:33 PM
amartinson's Avatar
Also check the second gear (sometimes called kickdown) band adjustment on the left side of the tranny. If it still is acting up, you could also have a shop do a few pressure tests on the trans. That will usually tell the story.
Old Oct 27, 2005 | 01:07 PM
Rrloren's Avatar
I didn't do mine cause I didn't know what was wrong at the time , however , had I known that was the problem I could have done it myself.
It's located towards the rear of the tranny on drivers side.
Let us know what the problem was when fixed.
Black Dog
Dec 3, 2009 08:18 PM
rattlebox01
Nov 6, 2009 12:28 PM
Mariner 250
Oct 10, 2006 03:31 PM
Madoco
Sep 8, 2006 05:45 AM
Holycack
Jun 27, 2003 03:26 AM
