2001 injector pump ?
Old Nov 27, 2004 | 06:54 PM
bcnu's Avatar
Does the injectors have pressure on them all the time(even when motor is not running),if so where is the check valve.
I changed the lift pump went from 8 psi to 19 psi at the injector pump.I can bleed the air out,the truck will crank,when i kill the truck it will not crank until i bleed the injectors again
Thanks,
Old Nov 27, 2004 | 11:42 PM
mysing418's Avatar
From: 13 miles N.W. of Cleveland, TEXAS in the National Forest
Are you bleeding air from the injectors every time or the low pressure side, banjo fitting on the injector pump? Fresh fuel filter? Click the link for good general r&r on lift pump.
http://dodgeram.org/tech/dsl/maint/3rd_Gen-24v.htm
Old Nov 28, 2004 | 09:34 AM
bcnu's Avatar
I have to open the line at the injectors & turn the motor over several times before it cranks.Thanks,
Old Nov 28, 2004 | 09:48 AM
bcnu's Avatar
MYGING418 do you know George polk & family.They live between cleveland & coldsprings,you turn left on dirt road past forest service?Thanks for your help.I live in Onalaska,Tx. but stay in dickinson,tx during the week for work.
Old Nov 28, 2004 | 09:00 PM
mysing418's Avatar
Do not recall the Polk family name at the moment. May have made an aquaintance during time and forgot ... Lots of good people out here. We bought this property in late 1999.
You get yer truck runnin right yet???
Old Nov 29, 2004 | 07:58 AM
bcnu's Avatar
Still not running,going to work on it some more today.Thanks,
chevelleriley
Jul 1, 2010 08:58 AM
Mariner 250
Oct 10, 2006 03:31 PM
Holycack
Jun 27, 2003 03:26 AM
Poor_Furd_Owner
Jan 6, 2003 10:47 AM
