2001 HO Injectors
Old Apr 19, 2006 | 08:12 AM
grzpdlr's Avatar
2001 HO Injectors
I'm doing a SVo conversion on a 2001 HO. I have a guy in Colorado that has agreed to modify the injectors specifically for veg but need a set of injector cores to send to him. Does anyone have a set I can buy?
Old Apr 19, 2006 | 08:19 AM
HOHN's Avatar
INjectors should NOT need to be modded to run SVO.
What exactly will he be doing to the injectors? You need to know that before you send him anything....
As for stock sticks, most guys who upgrade turn them in for core charge, so they aren't as plentiful as you may think. Still, you should find some pretty easily.. You've checked the classifieds, I assume?
Old Apr 19, 2006 | 08:22 AM
bnold's Avatar
I don't have the full injectors but I do have used nozzles....
Old Apr 19, 2006 | 10:00 AM
grzpdlr's Avatar
This a link to the guy:
http://www.coloradobiodiesel.com/
He modifies them for more flow, a more directed flow, a slightly higher pop-off pressure, and finally precisely balances the pressure between injectors to insure they are all the same. He is an extremely competent diesel mechanic.
Old Apr 19, 2006 | 11:05 AM
HOHN's Avatar
According to his website, they ONLY do Cummins injectors for 1989-1993 model engines. Either their site is old or....
Have you thought about the effect of higher popoff pressures on the injection pump.
I hope you have good luck with this, but I will tell you that a proper SVO or WVO conversion does NOT need modified injectors, from what I've seen. Granted I haven't read up much on it.
Still double and triple check to make sure that this is all you've been led to believe.....
jh
Old Apr 19, 2006 | 11:53 AM
Patrick Campbell's Avatar
For what its worth, greasel specifically recommends not running SVO on 24v VP44 trucks.
Old Apr 19, 2006 | 09:24 PM
BobQ's Avatar
I ran svo in my 01 for about 10,000 miles, all you need is a grease car type set up that pre heats the oil. You start on diesel and end on diesel, use the coolant to heat the svo. I never changed any thing else and it ran great. I made my own heater/filter set up.
Be aware, it is almost impossible to keep fuel pressure on the vp when running svo, it is just too thick, and nothing will pump it well. It will ad a whole new dimension to your lift pump issues!
If I was going to do it again, I would go the bio diesel route, also look into a svo/diesel mix! also a great alternative, as long as it doesn't get too cold out.
rattlebox01
Nov 6, 2009 12:28 PM
KRB
May 20, 2007 06:20 PM
Mariner 250
Oct 10, 2006 03:31 PM
BIGOKIE
Jul 21, 2004 05:53 PM
Holycack
Jun 27, 2003 03:26 AM
