2001 2500 transmission
Old Apr 1, 2013 | 09:55 PM
Wcoastmg's Avatar
From stop starts in second gear when in drive pull selector to first gear goes to first shifts fine after that. No codes and cleaned all grounds, connectors and added ground to transmission to frame any suggestions ?
Old Apr 2, 2013 | 11:27 AM
SIXSLUG's Avatar
Check codes, sounds electronic to me.
Old Apr 5, 2013 | 08:28 AM
jrs_dodge_diesel's Avatar
From the service manual, troubleshooting table for the 47RE:
Symptom:
No low gear (moves in 2nd or 3rd gear only)
1. Governor Circuit Electrical Fault. - Test with DRB3 scan tool and repair as required.
2. Valve Body Malfunction. - Remove, clean and inspect. Look for sticking 1-2 shift valve, 2-3 shift valve, governor plug or broken springs.
3. Front Servo Piston Cocked in Bore. - Inspect servo and repair as required.
4. Front Band Linkage Malfunction - Inspect linkage and look for bind in linkage.
Hope this helps.
Old Apr 5, 2013 | 08:33 AM
Mopar1973's Avatar
For grits and shins adjust your TV cable and add some throttle pressure. Adding it is moving the cable towards the firewall.
Mariner 250
Oct 10, 2006 03:31 PM
JBDIESEL
Oct 16, 2003 07:28 PM
Holycack
Jun 27, 2003 03:26 AM
Desert Diesel
22
Nov 12, 2002 06:14 PM
