1693 code... weird problem
Hey guys, i'm new to owning a diesel. One week Friday. I have read until blurry eyed on what to do with this. I bought this truck from my father and he told me their were some things wrong with it but wasn't sure exactly what. Its losing power at all speeds but its not a significant loss of power. I can be accelerating or coasting and it will drop 3 to 4 miles per hour randomly then pick right back up. sometimes it will do it 3 or 4 times in a row, sometimes only once. I did the key trick and got a p-1693 code and that's it. i thought they should do two p-done's but i only got one. Also he says the vp has already been replaced along with the lift pump. I did the apps reset and it hasn't solved my problem. Where do i go from here? Some threads I have seen say ecm or vp? what else is there? don't have money for two many repairs. He has no aftermarket gauges in either
Did I jump into something I can't handle?
P.S. literally knew nothing about diesels a week ago
Did I jump into something I can't handle?P.S. literally knew nothing about diesels a week ago
APPS wont always set a code ,I have replaced a bunch of them and most of the time there was no code, also by chance have you checked fuel pressure @ the vp? and hows the filter?also factory lift pumps are garbage seen them last 6 months
Lift pump and vp were replaced 30,000 miles ago. Maybe a year? I haven't checked the pressure at the vp not sure how to do that but I'm learning. I have a friend that can help me out with it once he's back from the oil field. Trying DIY right now. Filter is good replaced a three weeks ago. Thing that might put a twist is this had been going on for about three years but my dad never bothered to fix it.
Fuel pressure and electrical issues..... Check both. Find out what the fuel pressure is doing while driving and check both batteries and all major electrical connections and grounds. If you can, use a scan tool too see if you can pull another code since the 1693 is a companion code.
Can Autozone scan both the ECM and the PCM? If they only scanned the PCM, then the 1693 indicates a code residing in the ECM.
Went to autozone and they couldn't get any codes at all. I just got the 1693 when I do the "key trick" but I ordered the apps Sunday from timbo. Autozone said they scan both with it.
p-done means that the scan is done running through the process. And a scanner would pick up all codes too. The 1693 is a companion code and doesnt necessarily mean there's another code but its always a good idea to look if you're having trouble trying to diagnose an issue. Generally the companion code is letting you know that there is a communication issue somewhere with the ECM and the FPCM. Ya have to love the electronic age.
