02 24 valve Engine question
Old Apr 3, 2009 | 03:06 PM
ramruff's Avatar
Question 02 24 valve Engine question
A friend has an option to purchase an 02 club cab 2wd truck from the company he works for. It body wise is pretty nice, has about 180K miles on it, but has a couple mechanical issues. It starts right up cold with no miss or hesitation, but won't run down the road at any speed until it warms up for ten minutes or so. It gets to 1500 rpm & then acts like a governor is holding it back........the engine just quits fueling above that rpm till you drive it several miles (at 35 mph mind you !), then it runs fine........Any ideas ??
It never misses or stalls........It just gets the fuel backed off just like a governed engine.
(Yes it's full of fuel.......& fresh) Their service driver who had used it most recently said it's been doing this for awhile, & that's why the company is retiring the truck.
Any quick things to check ??
Thanks
Tom
He doesn't want to purchase the truck & have to spend more on repairs then he paid for the truck.
Old Apr 3, 2009 | 03:42 PM
j-fox's Avatar
Cylce the key 3 times ending with it on.
Then the codes come up in the odo window.
Check the fuel pressure. If it is lower that 5 under load, the lift pump and possibly the VP-44 ( injection pump) could be bad.
Old Apr 3, 2009 | 04:48 PM
wurkenman's Avatar
Do the key trick. If it shows a code P0216 tell him it will be about a 1k fix if he does it himself. That is the code for the injection pump.
Old Apr 3, 2009 | 11:09 PM
johnh's Avatar
sounds like a clogged fuel filter
Old Apr 3, 2009 | 11:41 PM
ramruff's Avatar
Thanks......I'll have him do the key cycling & see what code comes up.
Tom
Old Apr 4, 2009 | 08:00 AM
CamperDave's Avatar
Is it an Auto?? Did you try warming it up in Neutral for 5~10 minutes first?
Mine seems to take a while to fill the TC before it gets moving.
Old Apr 4, 2009 | 05:01 PM
HotRodTodd's Avatar
The MAP/Superboost sensor, about $83.00 will give you the same symptoms also.
Old Apr 4, 2009 | 07:51 PM
ramruff's Avatar
It has the dreaded po216 code, as well as 3 other codes that come up. I'll post the other codes when he emails them to me. Sounds like it might be best as a parts truck.
Thanks for the reply's.
Tom
Old Apr 4, 2009 | 08:42 PM
98whitelightnin's Avatar
Its gonna take more than a grand to get it going. The vp will cost at least a grand and then a good lift pump will cost another $500. If he's getting it for a good price it will be worth it to get it running again not just a parts truck.
Old Apr 4, 2009 | 08:51 PM
rich's Avatar
or he could spend about 1k for vp and about 200 for a holley blue. they work great had them on 3 trucks
Old Apr 5, 2009 | 05:46 PM
dodgeguy71's Avatar
Just cause the vp is shot it's only worth being a parts truck? Wow.....
Old Apr 5, 2009 | 09:32 PM
Kennys's Avatar
I guess it can be a number of things but mine was the VP-44. Fuel filter being clogged would not be affected by temperature. Mine did this for more than a year before it died. At least it died in the garage instead of 1000 miles from home. The code should show the problem.
Old Apr 5, 2009 | 09:38 PM
ramruff's Avatar
If he already owned it it might be different.......He hasn't bought it yet..........They want $2500 for it as-is and the PS pump is out too..........No power steering or hydro boost for the brakes........I drove it Thursday.......It was tough to say the least !
So add $1000 for the vp, $500+- or so for the steering pump fix, and their $2500 asking price & it's up to 4K for a 2WD 02 truck with 180K on it that needs assembled..........
Might be easier to find one that already runs without the work ??
Tom
piperca
33
May 11, 2004 06:40 PM
skinsey
Jul 17, 2003 05:47 PM
1320
May 17, 2003 03:28 PM
phildog
Apr 2, 2003 05:44 AM
