01 rear disc brake upgrade
I have a early 01 quadcab with drums
I just aquired a complete 01 with a disc brake rearend
it is all thats left of this truck is a cab and rearend
all the brake system appears to be intact on this unit.
Anyone know what all I would need to change to put this rearend
under the early 01. gear ratio is the same
or anyone direct me to a thread of someone that has done this swap.
Can't be as easy as just the rearend can it ?
Make sure the trucks both have the hydraboost and look for a proportioning valve for the rears. The e-brake cables are in similar positions on the drums and disc assemblies...you might be ok there. good luck.
Kurt
Kurt
I recently did this swap. Take the brake line splitter off your axle & screw the brake lines going to the calipers into your old brake spillter. You will need to shorten your drive shaft if you did not have a dana 80 before & u bolts will be be bigger. The parking brake bolts up but I have not tried to adjust yet. Mine worked with no modifiations to master cylinder or anything else beside I took the bed level censor and tied it up to mimic a fully loaded bed to increase rear brake power. They work great & every stop is consistent & has not locked up in rain or anything. Very happy with it & I now have a dana 80 since I had tore up 2 dana 70's. Good luck, Scott
1992 Renegade
Oct 11, 2014 03:29 PM
n2moto
16
Jan 22, 2009 10:25 PM
ShawnQ
Jan 12, 2006 08:09 PM
kwhite4
May 9, 2005 03:22 PM
