Rear Disc Brake E-Brake Adjustment
Old Mar 10, 2006 | 09:45 AM
scuzman00's Avatar
I went to apply my E-brake yesterday and noticed that it is not holding like it used to. Any comments on how to adjust them. I have never even looked at the set-up and the rear brakes work just fine.
Thanks in advance!!
Gary
Old Mar 10, 2006 | 09:58 AM
Barry St John's Avatar
In the past when this has happened to me it was because the pads were getting worn. It may be time for new brake pads.
Old Mar 10, 2006 | 10:51 AM
gofastman's Avatar
Smile
These dont use the disc pads for the e brake, it has a small drum inside the rotor than uses brake shoes. Mine did the same thing and found the rear axle seal was leaking ever so slightly and got the shoes wet, It never showed at that point that i had a leak from looking at the outside of the wheel or brakes them selves, until i took it apart. Might take at look at the e brake shoes to determine.
Old Mar 10, 2006 | 01:08 PM
hotdram's Avatar
jfpointer gave me this advice from the FSM:
Originally Posted by jfpointer
The procedure described in the FSM is to pull the rotor, measure the inside of the rotor, transfer that measurement minus 1/64" to the outside of the parking brake drums diagonally from the top of one shoe to the bottom of the other, then turn the star adjuster to make the shoes fit. There is, of course, a special tool for the measurements, but it just looks like a slide caliper capable of inside and outside measurements to me.
Also, Mopar1973man has a pic of the inside of the rear wheel assembly, showing where the starwheel adjuster is:
He also had a procedure for adjusting the E-brake:
Originally Posted by Mopar1973man
Inside this lil hole is a rubber plug. Pull the rubber plug out and inside the hole is a star wheel. I'm pretty sure to want to turn the wheel upwards to tighten.
The best way to set your E-brake pads are too...
Jack up the rear of the truck so the tires are off the ground. Then spin the starwheel till the pads start to grab. Then back off the starwheel till they stop rubbing. Then do the other side the same.
~Rob
Old Mar 10, 2006 | 04:13 PM
GreyTD's Avatar
Gary, the e-brake should not need adjusting (their just used for holding);unless something has gone wrong. As mentioned leaking oil seal, or e-brake pads dragging(not releasing completely) or someone drove the truck with the e-brake on . When applying the e-brake does the peddle go down the same or alot further than before. Either way I would take the rear wheels off check to make sure everthing is ok first before adjusting anything. just my 2 cents.
Old Mar 10, 2006 | 08:55 PM
J BODY's Avatar
Funny.....I find alot of them that need adjusting. DC has never had much luck with "self adjusters" of any kind.
Old Mar 10, 2006 | 09:20 PM
crobtex's Avatar
Mine is a '99 with shoes on the back. Is there a way to adjust the e-brake?
Old Mar 10, 2006 | 10:30 PM
HOdiesel's Avatar
With shoes there is a way to adjust them. They have a hole on the inside bottom with a rubber seal. Remove the seal and there is a star gear(?) that you can use a screwdriver to turn until the break just starts to slow the tire from rotating.
Old Mar 11, 2006 | 05:40 AM
crobtex's Avatar
Thanks. I thought that was probably the way, but I know some have some type of cable adjust.
Old Mar 11, 2006 | 08:34 AM
hotdram's Avatar
Charlie,
The FSM says adjustment of the parking brake cable tensioner is only to be done when the tensioner or a cable has been replaced or disconnected for service.
In other words, just adjust the starwheel
~Rob
Old Mar 11, 2006 | 08:36 AM
crobtex's Avatar
Thanks Rob.
Old Mar 13, 2006 | 01:36 AM
scuzman00's Avatar
A big thanks again for all of the replies. I was out of town for a long weekend of bobcat and varmint hunting and have just gotten back in tonite. I will pull the back wheels this week and give it a try at adjusting..... BTW, we scored 2 stuffable bobcats and my 15 yr old son bagged a 35 pound raccoon. It was the biggest coon I have ever seen in my 46 years.... Was proud of the boy for using his great grandpa's 1907 Fieldmaster single shot 22 at 60 yards, open sighted at 11:45 nite time shot too.... The joys of being a parent of a crack shot!!!! LOLOL
Gary
Old Mar 13, 2006 | 01:07 PM
GreyTD's Avatar
j body need your knowledge; what yr did the these truck come out 4 wheel disc brakes? I was under the impression that he had disc brakes. rear brakes being disc means rear internal drum e-brake shoes right? If they were holding before (adjusted properly) then how would they become unadjusted when they should only hold the truck not provide braking assistance. I've learn lots from this web site and need to learn more.
Old Mar 13, 2006 | 01:58 PM
hotdram's Avatar
Mid model year 2001 was when the 4 wheel disc brakes showed up (hence some folks saying they have a 2001.5). Prior to that, fronts were disc, rear were drum.
~Rob
pullin hard
Mar 5, 2009 08:06 PM
n2moto
16
Jan 22, 2009 10:25 PM
ShawnQ
Jan 12, 2006 08:09 PM
kwhite4
May 9, 2005 03:22 PM
drafalske
Sep 15, 2004 06:46 AM
