yes hx40 ?
Old Jul 22, 2009 | 10:47 AM
  #31
apwatson50's Avatar
... shutoff solenoid will probably stop working...
can't stop working if you don't have one
Old Jul 22, 2009 | 02:22 PM
  #32
bullfrog5.9's Avatar
yea cranked up pump with stock injectors means your shutoff solenoid will probably stop working and you'll have to use a cable hooked to the shutdown lever to turn the engine off
already got cable
Old Jul 22, 2009 | 07:42 PM
  #33
ok sweet
one step ahead
Old Jul 22, 2009 | 08:13 PM
  #34
92roughstock's Avatar
If you're slipping the Valair clutch with stock IC injectors, something aint right. Not that I'm saying Valair is a great clutch, but I'm in the lower 200's, and mine (organic) is holding just fine. Got it used with a flywheel for $190, IIRC.
Old Jul 23, 2009 | 12:27 AM
  #35
deerslayer1979's Avatar
Thats what I was thinking, since their warranty says they cover any workmanship defects I am going to call this a workmanship defect and get a new clutch. The flywheel was resurfaced when the clutch was replaced, and from what I was told it looked fine with only 2 spots showing heat marks, so it was in good shaoe and didn't need much taken off. It has got to be in the clutch/ pressure plate. I will know more after I talk to Valair.
DS79
vegasbound
14
Oct 13, 2003 01:46 AM
Hawkeye
Sep 23, 2003 08:22 PM
BarryG
Apr 1, 2003 03:07 PM
