Would 94 dually rear end fit 93?
Old May 29, 2007 | 09:29 PM
fitzydog's Avatar
I have the chance to buy a rear end for this project truck I found. It is a 93 dually single cab cummins, 5 speed, 2wd for $800!!!!!!!!!!! Guy wants it off his farm but it doesn't have a rear end and I can't tow it nor do I want to pay a flat bed to tow it about 70 miles. thanks Aaron
Old May 29, 2007 | 09:53 PM
rbrettctd's Avatar
Ill come haul it off for $800 if you dont want to!
Old May 29, 2007 | 09:56 PM
dieselpuller's Avatar
I just measured my 1992 3/4 ton 4wd with a Dana 70 and a 1999 1 ton dually with a Dana 80 and they both measured 43" from center spring to center spring. My guess is that you are in good shape!
Old May 30, 2007 | 09:30 AM
Field_boss_cb's Avatar
The driveshaft has to be shorten about 1 3/4 inch. Get the brackets and the u-bolts and nuts. The brackets need to be modified for the shocks to bolted to them ( this is easy to do).
Old May 30, 2007 | 10:37 AM
dieselJon's Avatar
I heard that the Dana 70 in 1st gens and the Dana 80 are almost the same. I know wannadiesel knows about it. Wait for him.
Jon
Old May 30, 2007 | 01:42 PM
I have a 1991 D-250 that I put a 1997 dually rear axle in. The tubes are larger in diameter, thats the reason for needing the brackets that go under the axle. The axle I have has outboard brake drums. This makes brake repair a lot easier. I would think that all the Dana 80 have this type of brake drum.
Old Jun 2, 2007 | 07:41 PM
fitzydog's Avatar
Thanks for all the replies fellas. I am still looking into this and how complicated it will be. Aaron
Old Jun 3, 2007 | 07:39 AM
Cowboy_Customs's Avatar
Either way you go, its a good investment. But understandably a pain in the butt to move.
Old Jun 3, 2007 | 03:23 PM
dpuckett's Avatar
If you were closer, I'd lend you my spare axle to ya to get it onto and off the trailer.
I'll send you a PM if I head that way in the next week or two.
DP
CLS LLC
Aug 27, 2011 08:15 PM
doorguy
Jun 8, 2007 06:19 AM
PontiacNUT
Mar 16, 2004 07:39 AM
RobG
Sep 5, 2003 09:13 AM
patriot pearl blue
Dec 9, 2002 08:53 AM
