Wont idle, new parts, why?
Old Sep 20, 2009 | 11:22 AM
  #31
12valvin's Avatar
Oh I hope not, if I do hook up this line to inlet line on the filter and it is still doing it then is that pretty much obvious VE problems.........dead pump or could something like a peice from my shutoff solenoid be in there in a bad spot?
Old Sep 20, 2009 | 11:34 AM
  #32
93flatbed's Avatar
I thought the shut off was mia?
Old Sep 20, 2009 | 01:18 PM
  #33
12valvin's Avatar
It is , but doesnt that peice brake off and go in the pump somewhere?
Old Sep 20, 2009 | 04:30 PM
  #34
Yeah, the pieces wind up in the delivery valves but it rarely causes any trouble. It would be isolated to one or two cylinders anyway, not the sort of trouble you are seeing.
Old Sep 20, 2009 | 06:14 PM
  #35
12valvin's Avatar
Ok well I hooked up a line to inlet tube to the filter and it still would not crank after I bled the injectors............
Does this sound like an air leak still or a bad IP, and are there anymore tests I might could run........?
Thanks as always
Old Sep 20, 2009 | 06:30 PM
  #36
As a last resort, hook it up to the VE directly to rule out a leaky fuel heater assembly.
Old Sep 20, 2009 | 06:51 PM
  #37
12valvin's Avatar
Would there be fuel in the oil if it was leaking?
Old Sep 20, 2009 | 07:24 PM
  #38
The front pump seal or a ruptured lift pump diaphragm will put fuel in the oil.
Old Sep 22, 2009 | 01:09 PM
  #39
Caver Dave's Avatar
Originally Posted by 12valvin
Any other input would be very heplful, im stuck in TN and need to get home.
Did you find the problem or at least band-aid it long enough to get home bro?
Old Sep 22, 2009 | 07:22 PM
  #40
12valvin's Avatar
Haha naw, IP is done. I hooked a rubber gas line directly to the low pressure inlet and it didnt change the outcome at all......but on a positive note im stayin with a buddy in TN whos got a shop soooooo I see the light at the end of the tunnel
Old Sep 22, 2009 | 07:38 PM
  #41
SOOT4BRAINS's Avatar
Pod Boy (on hiatus)
That sucks the pump is toast, glad you got a place to stay tho. Good luck!
Old Sep 22, 2009 | 07:52 PM
  #42
12valvin's Avatar
Yall been very helpful as always!!
Old Sep 26, 2009 | 02:15 PM
  #43
12valvin's Avatar
Ahh! I just put on the new IP and it still wont run! I followed the videos in the sticky and got it all done, im gettin fuel to the injectors but it still wont run!
Please help!
Old Sep 26, 2009 | 05:18 PM
  #44
93flatbed's Avatar
Same problem as last time, or wont run at all?
Old Sep 26, 2009 | 06:58 PM
  #45
Try a snort of ether to get it bled. Sometimes it can be hard to get all the air out and by then she's cranking too slow to fire.
