Window Electric Problems
Old Apr 11, 2012 | 04:32 PM
Jklawinsky's Avatar
My driver side window works sometimes and sometimes it doesn't. Here lately it hasn't been working at all. The passenger side still works perfect. I've checked the wires between the doors and cab and the relays seem to be working. I did notice it seems like my truck isn't charging enough and I noticed today while stopped at a light my amp gauge was had a tiny bounce going on. When I hit the driver window button the gauge still says its drawing power. The gauge really only reads low when I have the AC on but that's even at highway speeds. Anyone experience something like this before? Any help to tracking this booger down would be much appreciated.
Old Apr 11, 2012 | 05:20 PM
bannerd's Avatar
hello, It's probably the switch. You can get one of these and just unplug the switch. If you have power drawing from the battery this will light up.. just pull fuses or devices until the light goes out.
http://m2.sourcingmap.com/smapimg/en...en-163548n.jpg
Old Apr 11, 2012 | 11:14 PM
Jklawinsky's Avatar
Scout, I'll have to try that tomorrow. The thing that I don't understand is like 6 months ago I had the same problem but it only lasted a day and continued to work perfect without a hitch until yesterday. A few times if I turned the truck off and back on the window would work. The passenger side had a few moments too but not as bad. Another time the AC quit working as well! That led me to believe it was a relay problem but if one of the relays was bad wouldn't both windows not work? Sorry I've just always hated electrical gremlins
Thanks fellas
Old Apr 12, 2012 | 05:18 AM
dodgenstein's Avatar
Sounds like a flaky ignition switch.
Old Apr 12, 2012 | 07:27 AM
Jklawinsky's Avatar
Umm never connected this but sometimes the truck won't start unless you really push the gear shifter up into park or put it in nuetral.
Old Apr 12, 2012 | 07:36 AM
j_martin's Avatar
Sounds like a flakey truck.
If it's the ignition switch, other stuff like the radio will quit also.
When old technology DC motors near end of life, they can do all sorts of tricks. Intermittent operation is one of them. Excessive power draw is another.
Every dodge I've owned has had wires break in the loom that goes through the door hings.
Old Apr 12, 2012 | 09:00 AM
Jklawinsky's Avatar
I know what what you mean. My dads 07 had a couple wire break in there already. I guess I'll take the switch off and test it but all the wires in the loom looked good. I had one cracked with wire showing last time and I replaced it when it first acted up. I don't think it was the problem though. I'm just frustrated that I can't track it down.
Diesel Girl
18
Oct 6, 2013 03:03 PM
Rednecktastic
Aug 29, 2010 11:26 PM
cj5er
Dec 20, 2009 09:19 PM
j_stickers
Oct 4, 2004 04:19 PM
bigbaddiesel
May 31, 2003 03:30 AM
