Will this help my twins??????
I have a hx35/hx55 twin set up and on the hx35 I have a 12cm exhaust housing and was wondering if I put my stock exhaust housing on would it help out with spooling and boost?
Isn't the purpose of the primary/larger turbo was to cover the deficiencies in the smaller turbo at higher rpm's? Granted, the smaller one is still feeding the larger one, so is that why the restriction? I seem to recall Stomp running an HX35/HT3B setup, so it can't be that bad!
It spools good I know that I need more fuel but the boost is what I dont get it will only make around 38psi under full load. I would of thought that the twuns would do better than that. Th e hx35 as a single was making around 42 or so.
Or a boost leak. When you get on it do you hear a high-pitched squeaking kind of sound? If so, you have a leaker.
I'd go and recheck all your boots a 3rd and 4th time, just to be sure.
dodgediesel
17
Apr 5, 2011 11:21 AM
Stock 02
28
Sep 24, 2006 11:09 AM
stlsparky
Nov 21, 2005 10:02 PM
