Whos running electric lift pumps and do you like em???
Old Jan 13, 2009 | 11:36 AM
mviverit's Avatar
I was considering installing a airdog on my first gen. I am new to first gens and wasent 100% sure that I could do this. I considered doing a piston lift pump install but heard they were only good to 350 hp and I am hopfully going to have more hp then that within the next year. So my question is this what other setups work well and how hard is it to install an electric pump?
Old Jan 13, 2009 | 05:59 PM
I have a Walbro 392 on my truck. The fuel pressure gauge is boring.
Here's the thread from when I did the install:
https://www.dieseltruckresource.com/...d.php?t=120066
The Air Dog is a good setup provided you run it straigh to the injection pump, not through the stock filter.
Old Jan 13, 2009 | 07:15 PM
93John's Avatar
I'm running a holley blue, i have it regulated to 9 psi, it never drops. I just mounted it on the frame rail right in front of the tank and ran 3/8 hose to the filter. I've heard a lot of good things about airdog, but my setup was only about $180.
Old Jan 13, 2009 | 07:58 PM
JAyers's Avatar
Ive had good luck with FASS pumps and my Aeromotive A1000 has been pumping up to 50psi for about 13k now without any trouble.
Old Jan 14, 2009 | 05:08 AM
mviverit's Avatar
Wannadiesel that was an awesome write up. So since the airdog already has a filter I do not need the stock pump or filter anymore correct? Also If I install a new pickup line like wannadiesel did do I need to install a mess screen to filter out any big particals before it gets to the air dog? Would an airdog100gph be the best or a 150 (fear the pressure might be to high for the VE) Also how much psi can the ve handle???
Old Jan 14, 2009 | 05:34 PM
You can get the Air Dog set for whatever pressure you want. 15 psi is good. I would put a suction strainer in the line from the pickup like is in my Walbro writeup.
Where are you checking the pressure?
Old Jan 15, 2009 | 02:10 AM
mviverit's Avatar
thanks guys really appriciate the info.
Old Jan 15, 2009 | 12:28 PM
tcs 91's Avatar
i have an air dog 100 with filters. i found that if i cut the 90 degree mounting plate off the plate that squeezes the frame and drilled a couple holes in the [frame squeeze?] plate there was plenty of room for the pump/lines without inteference with the tranny. works best with the pump mounted straight down the frame rail. 15#s.[my 15# spring runs abt 12-13] don't want the factory filter in the mix. i like the idea of the filters, looks good in the tests with the air separator. website shows spray on a piece of paper with and without the air filter. tc
99TurboRamMan
May 26, 2014 10:12 PM
stock600
Dec 19, 2007 09:38 PM
Ilikebikes
Dec 11, 2006 10:13 PM
ratsun
Mar 18, 2005 02:05 PM
HorseHauler
24
Nov 16, 2004 06:01 AM
