Whos running a Mad ECM
Old Feb 24, 2005 | 10:43 PM
ratsun's Avatar
I would like to hear feedback from anyone who is actually running one.
I would like to hear honest opinions from people with first hand experience.
PM me if you like. I want to hear both good and bad (if any)
Thanx
Old Feb 25, 2005 | 06:59 AM
smittybuilt's Avatar
all i can say is i would hate to have to give it back!
Old Feb 25, 2005 | 08:31 AM
getblown5.9's Avatar
after the clutch that is going to be my next step...I want to try to make as much power as possible without a "fueling box"
that is why I made a thread last week about "boxless power"
with my current mods I am gonna do a Mad ECM, and dodgezilla (or similar hybrid) and see if I can break the 400hp mark with no fueling box...its gonna be real close
Old Feb 25, 2005 | 01:02 PM
24valvepuller's Avatar
Anybody with a big single or twins notice much difference in spool-up or being able to stay on top of them better
Old Feb 25, 2005 | 02:32 PM
Marco's Avatar
Whos running a Mad ECM?
Me.
Marco
Old Feb 25, 2005 | 02:55 PM
Wilson's Avatar
I am curious to see what the results of the injectors Don is developing, specifically for ETH and Marco's Ecm, will be. I think I will be the first one in line to get that set up as it sounds just right for me living in a higher elevation and using my truck the way I do.
Old Feb 26, 2005 | 03:22 AM
Dl5treez's Avatar
I have one of the first CaTCHER ecm's
To say it works great would be an understatement. Would have to bill it the #1 upgrade I've made to the truck so far.
Old Feb 26, 2005 | 03:30 AM
Dl5treez's Avatar
It can be done.
Old Feb 26, 2005 | 09:10 PM
joefarmer's Avatar
Without any boxes or ECMs my baseline is 415 to the rear wheels with Mach 6's. You shouldn't have much trouble hitting that.
brandon.
Old Mar 18, 2005 | 09:35 AM
RowJ's Avatar
Re: Whos running a Mad ECM
Thanx
Just installed a MAD ECM last week. Pulled out driveway...end of street onto hwy...said to myself, "what's up? No new learning curve on peddle control...no different than before with EZ/PM3 stacked"!
Than I realized I had turned my PM3 off, as a precaution for the restart, and had not turned it back on! And I was use to driving with PM3 on #9.
What I'm saying is MAD ECM and no box feels IDENTICAL to EZ stacked on PM3, on #9. Of course this is with 1/3 throttle or less...around town or at cruise on the highway, with the PM3 fueling only partially. Since the MAD ECM adds no fuel, it is different at heavier throttle settings but responsiveness for normal driving is extremely impressive!
With the TST PM3 turned on...it's downright scary, so far. I now drive around town with my box on 0.
RJ
PS - ratsun - With your FASS, and no fuel filter canister in the way, it's a 30 min install, max.
Old Mar 18, 2005 | 10:42 AM
OlBlue's Avatar
The CaTCHer spools turbo's much much better than stock ECM and boxes.
The CaTCHer with stock injectors and no box will spool a PDRHX40-16 very well. The PDR40 it lit to 10psi by 1500rpm, and is ready build boost at anything above 1100rpm. EGTs on the highway typically ran about 800 deg. Too much turbo (large exh housing).
The CaTCHer with stock injectors and no box will spool a 35/40 hybrid with ported 12cm housing when the engine starts! OK, that's a little bit of an exaggeration; however, there really is no lag. Putting around town at 25mph (3.54 gears and 315 tires), the engine is typicall just above 1000rpm....the boost gauge is typically at 4 or 5 psi and the needle follows the throttle, no waiting. Highway temps were around 650 deg.
I would recommend not going to a larger turbo with no other BOMBS except the CaTCHer. Just enjoy the throttle response of a gasser from your torque monster diesel! An improved intake and exhaust system are a must.
Old Mar 18, 2005 | 02:05 PM
seabee's Avatar
how well does the mad ecm spool up a small set of twins IE 35/3b combo cause this is what im looking at running along with a set of 155 hp injectors as soon as the tranny is done .
600 Megawatts
Jan 22, 2005 04:53 PM
TurboPirate24v
Oct 28, 2004 06:27 PM
FMF MX
45
Oct 19, 2004 08:18 PM
TurboPirate24v
Oct 8, 2004 12:46 PM
Battering Ram
18
Feb 19, 2004 01:03 PM
