whos building/built the viper black crew cab?
Old Feb 5, 2012 | 12:31 PM
19mike92's Avatar
i saw it yesterday when i was flipping through the archives, the truck i believe has a 4 inch lift in it is well, the reason i need to find them is because i thought i saw a pic in the thread involving the main wiring hookup. did they have to move it over an inch to one side or the other to clear the clutch bracket?
Old Feb 5, 2012 | 01:16 PM
93flatbed's Avatar
Yes it needs to be moved over. I had the same issue. But it's an easy fix.
Old Feb 5, 2012 | 01:23 PM
bryson711's Avatar
Its in the cummins conversion thread, its gyman98's truck
Sent from my DROID2 using Tapatalk
Old Feb 5, 2012 | 05:43 PM
19mike92's Avatar
how far does it need to be moved over? like an inch to the drivers side?
Old Feb 5, 2012 | 07:34 PM
bryson711's Avatar
Ya its about that, you just have to move it over far enough that you can drill a hole to install your master cylinder. If your trucks an auto you don't have to move it
Old Feb 5, 2012 | 07:47 PM
93flatbed's Avatar
? I just eye balled it. Mines about 1.5". Mine was ugly I used s saws all to extend the old hole, then welded in a piece of sheet metal to cover the over sized spot I made.
Old Feb 5, 2012 | 07:53 PM
bryson711's Avatar
I built a rubber grommit in that section on mine and then used it to runs wires through the fire wall into the cab
Old Feb 6, 2012 | 11:06 AM
gyman98's Avatar
The link to the build is in my signature, I basically just copied all the dimensions off the 92's firewall. If you need some help figuring things out just let me know.
Old Feb 7, 2012 | 06:52 AM
Trebor's Avatar
The plug/connector opening is enlarged over to the right by exactly 1/2 of the original width of the original opening. Then you cut a piece of body metal 1/2 the size of the original opening and weld it in place on the left side of the original opening. I made a template from an old firewall which I bolted onto the firewall and used as a guide to locate the exact factory positions of the newer openings. Mcmaster.com , Lowes, Home Depot, and usually your other local hardware stores sell the hole saws required to bore the clutch and wiring holes. On the mid 80's cabs there is one hole that need to be welded shut before you bore the new holes or you will have a missing chunk of firewall exposed. I guess if you don't care anything about your quality of work you could just gob this opening closed with a blob of silicone sealant or some electrical meter socket sealing clay?
Old Feb 7, 2012 | 11:05 AM
DHT's Avatar
DHT
Can someone post a pic of that black truck ,, I cant find it..Thanks
Old Feb 8, 2012 | 09:33 PM
gyman98's Avatar
All the pictures are right here:
https://www.dieseltruckresource.com/...d-t288785.html
Erska
Jun 7, 2017 07:47 PM
Lenny Boysen
Mar 9, 2014 08:17 PM
The_Head
Jun 5, 2009 07:27 PM
Banzai Bob
Mar 3, 2009 01:22 AM
farmer0_1
Jun 13, 2007 07:21 AM
