white smoke help?
Old Aug 18, 2010 | 04:07 PM
sgreen3's Avatar
white smoke help?
Got the 2wd running the other dfay after a rebuild. Runs an idles very well, but when you get on it in like 4th or 5th gear insted of black smoke it white. Pump was not removed when rebuilt. still at factory position. The truck runs good but it seems as it should have more power than it does I have turned the fuel screw up. Before I did that it would blow white smoke just on a real hard free rev. Could there be a problem with the KSB/ injectors are new, an have 18psi fuel pressure at WOT. So any help would be greatly appreciated. Thanks fellas!
Old Aug 18, 2010 | 05:03 PM
Onemoparnut's Avatar
18 psi @wot is a lot of pressure for a ve pump. Is there and oil in the water or water in the oil? Are you loosing coolant?
Old Aug 18, 2010 | 08:00 PM
Did you mix up the banjo bolts? The one that's supposed to be on the return line has a restriction.
Old Aug 18, 2010 | 08:01 PM
93flatbed's Avatar
Air in the fuel?
Old Aug 19, 2010 | 11:57 AM
sgreen3's Avatar
No not that I have noticed, an my bad read the gauge wrong only bout 14psi at wot
Old Aug 19, 2010 | 11:58 AM
sgreen3's Avatar
I dnt think so wanna, i dnt recall messin with any of the banjo bolts. witch ones are you talkin about?
Old Aug 19, 2010 | 12:00 PM
sgreen3's Avatar
Originally Posted by 93flatbed
Air in the fuel?
Its a possibilty i guess, my pice of junk holley pump just died after only having it for a week. but all the hoses an draw straw are brand new. What should I look for?
Old Aug 19, 2010 | 12:28 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
The one back by the power screw
Old Aug 19, 2010 | 01:11 PM
KD93's Avatar
I don't think air in fuel causes white smoke, but I could well be wrong. White is an indication of liquids, e.g. uncombusted fuel. If you just replaced your injectors, make sure they're all working like they should, and that you got the right angle spray pattern for your pistons. Also, check your timing. I know you said it's all stock, but check it again anyway. Are you 100% sure the timing gear went on at the right tooth mark, or was it retarded one or two?
Old Oct 2, 2010 | 11:28 AM
sgreen3's Avatar
I acually never took the pump off, but it seems to not be white smoking as much as it was. maybe it just needed some miles put on the new rings.
Old Oct 2, 2010 | 03:07 PM
dzl_damon's Avatar
compression? valves adjusted right too?
recone5
Nov 5, 2008 10:26 AM
RJOS
16
Sep 3, 2007 09:19 PM
BuildingBoost
Mar 25, 2007 07:46 PM
BlackSheep5
Nov 27, 2006 07:52 PM
dhe9
Nov 14, 2003 07:31 AM
