What's this thing on the radiator lines that rests creed thru?
1st Gen. Ram - All TopicsDiscussion for all Dodge Rams prior to 1994. This includes engine, drivetrain and non-drivetrain discussions. Anything prior to 1994 should go in here.
Stupid question, but I swear I just went through the whole service manual twice. What's this little round thing, and what are those tubes supposed to be doing? How do I reconnect them?
The round thing on the heater lines? It opens and closes so the heat can flow into the heater core to warm the cab.
Which line is chewed? The little grey vacuum tube?
If so you could butt it together and shrink wrap it, then splint it from the outside so it does not kink. I did that on a road trip to get my 4x4 lines working on my 2nd gen.
I agree with Oliver...but I will amend that the actual function of this heater control valve is to shut off the coolant flow through the heater core to minimize the heat in the HVAC box when you turn on the AC system.
If I remember correctly these are not reproduced or available in the aftermarket...at least the last time I checked a few years ago. I needed a new one for my crewcab and after extensive searching I found one from a 90's Ford Ranger that had the correct hose connections and functioned as original.
