radiator removal and trans lines
Old May 27, 2008 | 01:45 PM
Ed ke6bnl's Avatar
When I remove the radiator in my 98 ram 24v. diesel engine, do I need any special tools to remove the transmission cooler lines out of the radiator??" thanks running short on time, leaving for vacation when I pressure tested the radiator I had a leak at the tank/coil seam. The radiator shop says it is better for him to just change out the tank then for me to put in an after market Chinese radiator. whats your thoughts. Ed
Old May 27, 2008 | 06:58 PM
Invader's Avatar
my 99 didnt have trans lines going to the radiator. It has a sep cooler. Just had upper / lower hoses and cap.
Old May 27, 2008 | 11:50 PM
Ed ke6bnl's Avatar
Thanks for the reply when I read the big manual on the truck it told of the separate heat exchanger for the trans and the external as well. thanks again. well on the way to the install.
stan
Aug 7, 2014 09:43 AM
8liter
Sep 22, 2012 10:19 AM
EClancy
Jan 16, 2007 09:27 AM
MrKen
Feb 25, 2005 04:22 AM
hellotbone
Sep 1, 2003 08:46 PM
