What's that noise
Old Apr 19, 2017 | 01:01 AM
KRB's Avatar
KRB
Man I was hoping it was something simple like the exhaust vibrating on the frame, not the crank!
Old Apr 19, 2017 | 02:38 AM
bigragu's Avatar
Just rule it out with a simple check using an indicator.
An oil analysis can also tell, if you have excessive metals in your oil.
Old Apr 19, 2017 | 11:51 AM
u2slow's Avatar
I haven't torn into mine yet. Unsure if this truck will see the road, or become and engine donor. But before either happens... the endplay will be something i'll check for sure. Timing cover will come off for inspection and KDP. Check out the vac pump thoroughly at the same time.
Old Apr 20, 2017 | 11:19 AM
edwinsmith's Avatar
Timing gears?
That's what it sounds like to me. Just the gears slapping against each other at low idle. I wouldn't worry about it until something comes through the case. My G360 makes a similar sound when it's in 4th below 1500 rpm. The cluster gear has no load and is slapping things around. Hopefully some of that noise will go away when I get the trans swapped out on Friday.
Edwin
Smkn600CTD
May 22, 2012 07:21 PM
ShowMe06
27
Jan 4, 2008 11:47 AM
Tackdriver
Mar 12, 2003 01:58 PM
powerstrokethis16
Mar 9, 2003 09:40 PM
Jones0027
Oct 22, 2002 07:39 AM
