Whats the advantage of having a pull cable shutdown?
I see a few guys on here have whats called the "pull cable" shut down. I'm assuming this is like 95% of tractors out there. What are the advantages to this? Isn't shutting the motor down, shutting the motor down? Could someone enlighten me?
Thanks
Lucas
Thanks
Lucas
The advantage is not having to buy a new shutdown solenoid every time you make a full power high RPM run.
Many trucks that are turned up a bunch eat the solenoid plungers at an alarming rate.
Ah that makes sense then. I've seen at my local napa some generic choke cable setups. I think that would work no? Does anybody have some pictures of their setup?
Thanks,
Lucas
Thanks,
Lucas
At the shop, I get to see about every kind of rigging that there is.
Hardly a Dodge/Cummins, over five years old, comes in that doesn't have some kind of a homemade kill cable.
I have seen everything from grass-strings with a loop over the turn-signal lever, to baling wire with a corn-cob handle.
Oh man, that's rich!
Corncob!!!!!
Should work fine. I think it was FeartheDeere who had a piece of baling wire with a fence insulator for a handle. It doesn't have to be complex.
Thanks,
Lucas
Thanks,
Lucas
, that's from NAPA.
Kirk T
Sep 20, 2006 07:19 AM
BIGTAN408
Mar 28, 2006 08:17 AM
hellotbone
Oct 7, 2003 06:54 AM
Fishinghaoliboy
Jun 30, 2003 09:38 AM
