what tool to grind fuel pin?
so im looking to grind my fuel pin and was wondering what i can use to grind it. i was going to buy a 120grit flapwheel for my 4 1/4 grinder and jut go slow or is there something else i should use?
Also check with the local cnc/machine shops. I had a pin sloped for a gate which was very similar to the denny-t fuel pin. The slop on the pin was a stop basically. Anyways, they did it for $10 and it took a few minutes.
3 inch cut off tool works best by far. just plug it straight into the wall or clamp it in a vise then you have lots of control lightly gringing back and forth with the pin. Dip it in some water every now and then to keep it cool. Whole things takes about 2 minutes. Long as you grind lightly dont even have to clean it up with a flap wheel
Here's a good write-up of the fuel pin grind... https://www.dieseltruckresource.com/...d.php?t=154086
Here's a couple more... https://www.dieseltruckresource.com/...e-t241169.html This one has some good pics... https://www.dieseltruckresource.com/...d-t236084.html
