What is the minimum ca to turn over?
Old Apr 30, 2019 | 03:35 PM
Torque_Junkie's Avatar
What is the minimum cranking amps to turn over a 1st gen cummins? My dad is saying my starter is out but I don't think the 890 CA (710 cca) battery is enough. The starter engages but doesn't turn. Thank for the help again guys!
Old Apr 30, 2019 | 04:18 PM
edwinsmith's Avatar
Your starter contactor is probably bad and not making contact between the battery and the motor. The solonoid is engaging but the contactor isn't making contact. You can buy a kit to fix the problem.
https://www.amazon.com/gp/product/B007FR3JVI/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B007FR3JVI/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
You can also replace the brushes while you're at it.
https://www.amazon.com/gp/product/B00D2C1QNI/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B00D2C1QNI/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Look in the stickeys and there should be an article showing just what to do.
Edwin
Old Apr 30, 2019 | 07:27 PM
So the 890 amp battery would work? I'm just getting a remanned starter for the warranty. Thanks.
Old Apr 30, 2019 | 07:30 PM
edwinsmith's Avatar
I ran an 850 cca battery for a couple of years. The gear driven starter works very well.
Old Apr 30, 2019 | 10:36 PM
j_martin's Avatar
The gear starter is pretty thrifty. Battery isn't a big factor unless you have to crank long, or in below zero weather. Then a good, heavy one is everything.
Old May 1, 2019 | 01:01 AM
I have fored mine up with a spare 750 CCA battery before.....no issues. Your fathers truck has other issues, starter, battery cables etc.
Old May 1, 2019 | 08:36 AM
Smile
Thanks for the help as always you guys have an awesome response time and are incredibly knowledgeable about these trucks.
stealman1
Nov 9, 2007 11:07 AM
ktpul
Feb 13, 2006 08:01 PM
bigfoot
Jan 31, 2005 05:44 PM
bigfoot
Aug 14, 2004 02:22 PM
Mechanos
Jun 27, 2004 03:38 PM
