What donor hydroboost is the easiest/best for a gen1
Ok,
Some of you have done this upgrade. I've found gen 2 and gen 3 used ones. Chevy ones fro. Early 2000s. Any suggestions on what is the easiest?
M
M
I'm working with a couple GM square-body ones (81-87). The mounting plate has a slight angle to it. Not installed yet, but I think it will be ok.
I believe the GMT400 ones (88-98) have a straight plate. I don't like how long the 2ndgen Dodge ones end up being. They have the extra bracketry to clear the cowl.
Do you know if other common Dodge/GM masters fit? Or does it limit you to the Astro/Safari one?
Not to hi jack but to hopefully add clarity for myself and future researchers.
On The earlier 12 valves you have to replace the PS Pump to do the conversion, so you have the extra port. Does this need done on a 93 or only earlier trucks 91.5 and older?
Yukon Ram Grrl
Jul 11, 2010 09:16 AM
