what cranking amps do i need?
Old Jun 29, 2007 | 01:26 AM
mullishacrew's Avatar
hello i have a 1993 dodge with the cummins turbo diesel and the battery thats in there is puny and definetly not what came with it, whats the stock cranking amps for the battery? thanks Gregg
Old Jun 29, 2007 | 01:53 AM
loch's Avatar
The farther north you live the more CCA you need. But I think most came with a 900 or better.
Old Jun 29, 2007 | 05:48 AM
JD730's Avatar
I consider a group 31 with 900 CCA or more the min in the winter where I'm at. I think most of ours are 925 CCA IIRC.
Old Jun 29, 2007 | 06:28 AM
gomerpile's Avatar
it says in the manual that it needs to be 1025cca
Old Jun 29, 2007 | 09:15 AM
MDLP412's Avatar
ive got a 1125 on mine.... 150 bucks no porblems tho
Old Jun 29, 2007 | 10:12 AM
gman07's Avatar
I have a 1000 CCA battery in mine. IIRC it cost around $80.
Old Jun 29, 2007 | 10:23 AM
Jims92CTD's Avatar
Battery
I've been running a Interstate Workaholic battery for years. I think it is rated at 960+cca and never had a problem. I check the water level regulary and seal the posts with RTV and then put the felt pads on. Sealing the post keep your cables from getting screwed up.
The present battery I have was used in Arizona for a year or so in the heat and it made it through a winter here in Oregon with no problems. The main thing that kills batterys is not cheching the water level, this goes for any brand you moght by except the gell type.
Jim
Old Jun 29, 2007 | 11:21 AM
jjdiesel1990's Avatar
I've been using a $100 dollar battery from Napa for the past 8 years with 1200 cca. Never had a problem what so ever.
Old Jun 29, 2007 | 12:47 PM
searcher's Avatar
You need at least 1000 CCA. You might call your local school bus barn and ask where they buy their batteries. I did and found that they were $85. I went to pick it up and they had several blems for $50 each.
Old Jun 30, 2007 | 02:56 AM
ahh thank you, thank you thats a great help because i really need a battery soon i wanna put the truck on the road and test it out, and i knew the battery it came with was much to small 760cca , surprised it even turned it over.
doug60
Jun 29, 2005 11:22 AM
I PASS GAS
15
Mar 13, 2005 02:53 PM
durasmack
Mar 7, 2005 10:07 PM
royta
37
Dec 19, 2004 02:44 PM
dodgedude361
20
Nov 11, 2004 09:00 AM
