Leaky inj pump
Old Jun 29, 2007 | 07:52 PM
Jethrro's Avatar
Leaky inj pump
Just bumped the timing on the rig today and somehow I have a leaky throttle shaft. Well since I have to pull the pump top to replace the O ring seal was wondering if it is absoultly necessarry to retard the timing on the pump to do this. Thanks Jethrro
Old Jun 30, 2007 | 12:28 AM
Micaiahfied's Avatar
first i would pull the throttle shaft and reinstall it correctly. i had one leak after doing something so i pulled it and reinstalled it, never had a problem again... you have to make sure it's pulled to the correct height.
Old Jun 30, 2007 | 12:43 AM
edwinsmith's Avatar
Once you have the pump top off the throttle shaft o-ring is real easy to replace. Just mark the timing position when you move the pump. Be sure you loosen the bolt in the bracket in the back or you'll have a heck of a time moving the pump.
Edwin
Old Jun 30, 2007 | 06:12 AM
It's a whole lot easier to work with the pump retarded all the way. 3 nuts and a bolt will save you a lot of hassle.
RussianVolk
Jun 29, 2010 01:13 AM
Jim5870
Jan 25, 2010 11:29 PM
janb
Mar 25, 2007 07:48 PM
9 sec camaro
20
Aug 26, 2006 01:30 PM
hotmopr
Jun 29, 2006 10:22 PM
