Holley blue - how many amps??
Old Jun 29, 2005 | 09:25 AM
doug60's Avatar
The scotty smart fuel system & the Holley blue. Stock fueling it pulling the pressure down to 11lbs. I don't think its going to be up to the task of supporting the mods to come. So I'm looking into an alternative pump. The Holley is powered buy the stock wiring, my question is, how many amps will the stock truck wiring be able to handle??? The pump I'm looking into will pull between 5 & 6 amps. Is the stock wiring adequate??
Old Jun 29, 2005 | 11:15 AM
nickleinonen's Avatar
if in doubt, run it on a relay controled by the stock wiring...
Old Jun 29, 2005 | 11:22 AM
banshee's Avatar
The Blue pulls right at 4 amps. Reinstall the stock LP and run the fuel through the blue and through the stocker. It'll be plenty of fuel for all the power you can make. I get a min of 16 psi at full tilt with mine.
The stock wires are very small 18 gauge, so 6 amps would be a lot for them. Use a relay to power it and trigger it with the stock wire.
John
AlCorr
114
Feb 11, 2009 02:32 AM
Texaschevelle
26
Nov 16, 2007 08:08 PM
CTD2001
Mar 22, 2007 08:28 PM
Common
Sep 5, 2006 11:01 PM
I PASS GAS
15
Mar 13, 2005 02:53 PM
