What to adjust?
Old Jun 16, 2007 | 12:50 PM
GaCamper's Avatar
What to adjust?
A fuel pump dummy asking questions here!
Installed the fuel pin. Went to test drive. Noticed that the truck seems to be sluggest from a dead stop. Once the RPM's gets up it does good. Also I have little if no smoke now.
What adjustment should I make first so the truck is not so sluggest? Or what steps should I take to make the right adjustments?
Note: I use this truck mostly for pulling so I need to becarful not to get my temps to high
Thanks
Old Jun 16, 2007 | 01:01 PM
dpuckett's Avatar
You can loosen the AFC spring tension (I think it is called the starwheel, but it looks more like a gear. I'm curious who was smoking what when they named it that). turn the gear/ wheel counter clockwise a few turns. This increases the rate of fuelling increase, but keeps peak fuelling the same.
Did you get the pin installed with the tapered flat face facing forward? (Just asking; I have no idea what instructions are or arent included in those kits)
If you have gauges, try a turn on your full fuel screw. Keep an eye on temps, and if you lack a pyro, leave this one alone- you can get hot in a hury.
Daniel
Old Jun 16, 2007 | 01:18 PM
GaCamper's Avatar
The pin is facing the right way. I do have a gauge so I can see the temp...I'll give the star wheel a spin and see what happens..Thanks for the info
Old Jun 16, 2007 | 05:02 PM
GaCamper's Avatar
I got it going now. Once I turned the fuel screw out 1 1/2 turn the old truck woke up....At 60 mph with no load the exhaust temp is running 480 to 500 on cruise....
Old Jun 16, 2007 | 07:01 PM
Cowboy_Customs's Avatar
Am I reading things backwards here, or r they typed that way? lol
You can loosen the AFC spring tension.....turn the gear/ wheel counter clockwise a few turns
Clockwise loosens the tension
OUT 1 1/2 turns woke it up?? or IN?
Old Jun 16, 2007 | 08:33 PM
GaCamper's Avatar
Sorry I type it wrong...I did turn the fuel screw in 1 1/2 turns.....
Puke
Jul 23, 2003 01:07 PM
thumbs
May 7, 2003 11:45 AM
mymaur
Jan 9, 2003 11:02 PM
whiteknight
17
Jan 8, 2003 10:38 PM
