well i think my IP pump give it up today
Old Sep 20, 2008 | 09:50 PM
winkdemon's Avatar
i have 10psi fuel pressure under load and there is no smoke so i am thinking the IP give up the ghost the truck won't smoke at at any more then 1500rpm ..... any ideas if its not that .. putt a new fuel filter on to ....
Old Sep 21, 2008 | 12:34 AM
SkinnyBTN's Avatar
When my pumps started going bad and loosing power I had grey/white smoke and hard starts. It was very noticeable that it was on its way out. But they may not all do like mine. Have you checked your shut off solenoid, if ya have one?
Old Sep 21, 2008 | 01:52 AM
winkdemon's Avatar
it starts easy ,,, and has no grey smoke but no black smoke
Old Sep 21, 2008 | 01:54 AM
89f150's Avatar
what about lift pump? not puting pressure to the ip?
Old Sep 21, 2008 | 02:00 AM
winkdemon's Avatar
my gauge is at the lift pump
Old Sep 21, 2008 | 02:06 AM
89f150's Avatar
oi wonder if there are anyways to test the ip
Old Sep 21, 2008 | 07:05 AM
SkinnyBTN's Avatar
Have you checked the shutoff solenoid. Sometimes rubber gets torn off and blocks passages in the pump/injector system.
Old Sep 21, 2008 | 07:21 AM
ofcmarc's Avatar
Any chance yo live in an area where they switch to #1 in the winter? #1 gives less power/smoke compared to #2. Truck will start/run the same. Be sur to run a lubricity additive if this is the case.
Old Sep 21, 2008 | 07:50 AM
Things to check before condemning the pump: Throttle lever travel - are you getting full travel at the pump when the pedal is floored? AFC boost line - is it cracked, is the fitting at the head tight, and is the banjo bolt tight? A boost leak here will kill power. Last thing: Pull the AFC cover and power pin, then cycle the throttle lever while you watch down the hole. A little pin ought to pop out from the front. If it doesn't, it's stuck and is your cause of low power. Sometimes some penetrating oil or carb cleaner will get it going without having to take the pump apart.
Old Sep 21, 2008 | 12:24 PM
winkdemon's Avatar
it has no leaks i check the afc pipe is changed i made a new one so the air supply gets therefast and it works nicly .. but i will check the afc pin to see if it coming out or not .... but if i have to disassemble it i will just leave the lever out so it will have alots of fuel ... but thanks
Old Sep 26, 2008 | 01:57 AM
MikeThomas's Avatar
Haha, mine is impossible to start when its hot...time for a pump for me too...sigh
Old Sep 26, 2008 | 11:34 AM
pwrtripls1's Avatar
mine starts right up just fine but spews fuel out all over the place. I get 100 feet per gallon. lol
roxxx
ABDTR #5
21
Jun 23, 2011 11:21 AM
Cummins Freak
Jan 3, 2010 10:00 PM
westcoaster
Feb 26, 2008 10:41 AM
Brules
25
Jul 14, 2004 05:28 AM
