Weird Steering Problem & it won't go away
Old Nov 2, 2008 | 08:29 AM
That'll do it.
Old Nov 3, 2008 | 10:58 AM
diesel fuel's Avatar
Id suggest when you buy your axle joints to make sure you get the ones with the grease
fittings . So you can always keep them lubed ...
Old Nov 3, 2008 | 07:38 PM
Power Ram 250 C's Avatar
10-4 on that. Bought 2 at napa today, kind o pricey though, $54 a piece. But they are greaseable.
Old Nov 3, 2008 | 07:52 PM
faylorz's Avatar
this thread is a savior. my truck does not want to drive straight in fact it jerks randomly the entire time. it smooths out.....kind of over time but whenever I turn it starts doing it again. 54 a piece though?!?!?!?!?
Old Nov 3, 2008 | 10:45 PM
kellypckp's Avatar
I had a problem were when I would turned the wheel it did some to come back. I had to force it back straight. Come to find out that it was the clock spring behind the steering will. It had came apart and was twist up. I find it out any I had no cruise control any more.
Not sure if that will help but some info.
Old Nov 4, 2008 | 09:49 PM
Smile
That's exactly what mine was doing. Everything is back together now and will test drive tomorrow to see if it fixed it.
Old Nov 9, 2008 | 07:47 AM
Yep this fixed it. I am happy now, no more severe jerking into the other lane now. Thank you guys for all your help.
Old Nov 9, 2008 | 10:15 AM
BearKiller's Avatar
I read this thread for the first time just now.
Of the many part-time 4x4 set-ups that I have had experience with, not a single one would behave as you would figure they should.
With everything UN-LOCKED and transfer-case in 2WD, you can take hold of the front shaft and spin it with ease, assuring that everything is free; but, drive the truck down the road and the front shaft and axles spin like crazy.
I have witnessed many cases where the 4x4 was NEVER locked in, yet the front axle U-joints and the front drive-shaft U-joint and C-V-joint were worn out completely, simply from coasting along.
One would think that with everything un-locked and supposedly FREE that it would just hang there dead and go along for the ride, but that is not the case.
To demonstrate this, fix up a card-in-the-spokes type noise-maker on the front shaft, or attach a bright colored stiff plastic flipper on the shaft, down close to the front differential, and observe from the sidewalk while someone drives the truck past.
Mysterious, I know, but true; believe it or not.
Tobin
Apr 6, 2012 05:58 PM
NE frmhnd
May 16, 2010 08:45 AM
Common
Apr 9, 2008 10:25 PM
Machinos
Mar 16, 2008 01:34 AM
Bobcat698
Oct 2, 2006 09:08 PM
