water pump
Old Jan 29, 2007 | 02:33 PM
gcliburn's Avatar
water pump
I think my water pump is leaking. I checked with cummins and a remanufactured one seems kind of expensive, but I want a good one. I was wondering if anyone knew of a less expensive alternative, or if it is better to just stay with the cummins part.
Old Jan 29, 2007 | 05:10 PM
jcsd250's Avatar
Before you replace it, pull it off and see if its damaged. If not get the
o ring and reinstall. If it stops the leak it should be an easy fix.
Pulling the pump is as easy as it gets. 2 bolts and you'll see where the o ring is.
Old Jan 29, 2007 | 05:16 PM
I'm running a brand-new aftermarket one (OK, it's 2 years old now), it cost me around $50.
Old Jan 29, 2007 | 06:09 PM
KAyers's Avatar
From: Springtown Texas, the land of MILFs and Honeys
+1 on the aftermarket.
I got mine at O Reilley or similar. No problems. I believe it was around 60 dollars.
Do the molded hoses and radiator hoses while you're doing the pump too. Shouldn't add more than 30-40 dollars to the ticket.
Old Jan 29, 2007 | 06:14 PM
Boatnik's Avatar
I have found NO problems with the NAPA pump so far. In fact it looked more hightech than the OEM replacement. I put it in in March, I think? Can't remember for sure, but it isn't hard at all.
ted_pulliam
Oct 15, 2009 08:24 AM
RamWheelsBy4
Apr 11, 2007 04:43 PM
kev211
14
Feb 22, 2007 03:39 PM
Gene Peterson
Jan 7, 2006 02:32 PM
