Water in oil
the head was checked for cracks and the head did bump the gasket the first time but not the second. i have been told that the heat exchanger going bad would put oil into the water not vice-versa?
oil cooler leaks will put oil in your water. oil pressure is much higher than coolant system pressure.
true enough, I hadn't thought about it that way. Mine went at freeway speed, so there was little to no mixing of water in my oil, just the other way around.
4320Diesel
04-25-2011 09:50 PM
Gene Peterson
01-07-2006 02:32 PM
SmokinDodge12V
12-01-2002 08:44 PM
