Water in the fuel
Old Mar 17, 2012 | 08:13 PM
440727's Avatar
Water in the fuel
I know this has been address before but i can't seem to find it.
I just bought a 1992 D350 which has been sitting for about a year.
When you go to start the truck the idiot light says water in fuel during start up and while running.
I pushed the plunger on the bottom of the fuel filter up while the engine was not running 3 times until it was empty. Then i would turn the ignition until the accessories came on for 20 seconds times 3 to prime the lines again before starting. Hope i'm doing this right.
Long story short the idiot light is still on ? What should i do next ? New fuel filter and ?
Thanks guys !
Old Mar 17, 2012 | 09:08 PM
gyman98's Avatar
You don't have a electric fuel pump (unless its aftermarket) If the truck has been sitting for a year definately change the fuel filter. There's a lever on the lift pump you use to prime the system back up after you change the filter or drain the water
ZPOD
18
Sep 23, 2010 10:37 AM
DodgerDoob
Oct 1, 2008 07:49 AM
nooska
Jun 19, 2008 08:30 AM
kev211
14
Feb 22, 2007 03:39 PM
Gene Peterson
Jan 7, 2006 02:32 PM
