piston lift pump advantage
Old Mar 17, 2012 | 12:00 AM
mullishacrew's Avatar
so i see alot of people putting the piston lift pumps on there rigs, whats the advantage of this? how much more fuel does it flow any problems with our ve pumps holding pressure?
Old Mar 17, 2012 | 12:10 AM
The_Head's Avatar
I'd say it flows 150-200 whp more than the stock diaprhagm lift pump. The low pressure version is great for the VE injection pump. It puts out about 15 psi which is where the VE likes it.
Old Mar 17, 2012 | 10:14 AM
ofcmarc's Avatar
It won't pump your crankcase full of #2 when the diaphragm fails...... (cause there ain't one)
Old Mar 17, 2012 | 11:41 AM
bobva's Avatar
It also helps increase the cooling of the Injection pump.
That is why you would want it on even a stock motor.
Old Mar 17, 2012 | 01:56 PM
is there a hp gain just adding it?
Old Mar 17, 2012 | 04:10 PM
The_Head's Avatar
No there is not.
Old Mar 17, 2012 | 09:00 PM
dieselJon's Avatar
Someone explain this to me. Everyone says this but I cannot find it true.
The more you compress/pressurize something, the hotter it gets. So going from 2-5psi to 15psi would increase the heat of the fuel before the IP. Now the IP then pressurizes it even further to 100-300psi. Now you have more going in but the outlet is still restricting which helps keep up the pressure for the stock system.
It goes against logic to say that.
Now if you are draining the case, then I see the benefits outweighing the bad. But on a stock system, no.
FWIW, the newer big rigs have a fuel thermostat. The cooler the fuel the more power up-rating it gets. Put a resistor in line and gain 20-50hp as the ECU thinks the fuel is cooler. Some people have also said putting a fuel cooler on the return of their CR's helps with EGT's.
Old Mar 18, 2012 | 10:24 AM
Nadir Point's Avatar
Fuel Temp Issues
Maybe if it's doing this:
Originally Posted by dieselJon
Now if you are draining the case, ...
The entire tank is turned over by normal circulation while running in some short period, probably less that around 10-20 minutes depending on how much is in there. So fuel temp seen by the injection system is more a long term cumulative function over time than anything else. This may become an issue during hot summer months, especially with the tank running low.
I run fuel coolers in the return lines on both my trucks.
Old Mar 18, 2012 | 11:12 AM
bobva's Avatar
Thanks Nadir Point
That also makes more sense into what I said in post 4.
DieselJon
Thanks for your input on to what I've always read here also. That I to also posted above.
Seams like there is from time to time a piece of the puzzle missing.
Fuel cooler
I got a few automatic transmission coolers not laying around anymore.
PapeCAT
Dec 9, 2017 03:23 PM
GIT-R-DONE
Aug 24, 2011 10:27 PM
BurrisWill
May 29, 2009 12:58 AM
CTD99
13
Aug 23, 2005 10:55 PM
The Old Man
Dec 18, 2003 11:32 AM
