want to advance timing
Old Mar 26, 2008 | 06:48 PM
ofcmarc's Avatar
Originally Posted by dzl_damon
Looks like an easy proceedure, but I don't have a wrench that will get to that lowest pump mount (the s wrench)
It can be done with out the s wrench. It is a PITA though...
Old Mar 26, 2008 | 06:58 PM
big stinky's Avatar
The first time I did it, i didnt have a s or a c wrench. Then when I went to tighten it back up, i couldnt get my wrench in the top bolt cause the diaphram housing was too close to the head. Was a real PITA. I ended up buying "C" wrenches and they worked awesome. Saved lots of grief.
Old Mar 26, 2008 | 09:48 PM
Alwaysworking's Avatar
alwaysonDTR
i just cut a cheapo wrench in half and welded it in a c because my c wrench wouldn't fit.
Old Mar 26, 2008 | 10:02 PM
daking's Avatar
i went to snap on and 40 bucks later i walked away with an s bent wrench, made life alot easyer, was expensive
Old Mar 26, 2008 | 10:32 PM
rattlerbob5.9's Avatar
Talking
I just bought a somewhat cheap wrench and then used my blue tip wrench to fine tune it i now have a great pump wrench for 2 minuets work and a couple of bucks.
Old Mar 27, 2008 | 12:13 AM
stackx2's Avatar
i just took a torch and bent mine into an L shape
Old Mar 27, 2008 | 04:15 AM
Chrisreyn's Avatar
wha tsize are those bolts again? and how long a wrench is needed( thinking of buying an elcheapo and bending it)
Old Mar 27, 2008 | 08:07 AM
daking's Avatar
there 12mm
i bent 4 wrenches trying to get the right shape and either i mested up the head or i broke it,
Old Mar 27, 2008 | 05:41 PM
No, they are 13 mm. The cheapest wrench you can get from Harbor Freight would be a good one to bend.
Old Mar 27, 2008 | 07:26 PM
Yes 13mm is correct sometimes a well worn/sloppy half inch will work.
Put it in the vise and warm it you don't need it too hot and bend it the longer the wrench to start with the better.
Put one bend in it for an L or two if you want more of a U
wvopowered
Apr 22, 2008 06:00 AM
Davidp
Mar 16, 2003 11:40 AM
95ramtough
22
Jan 29, 2003 08:45 AM
Smokin
Nov 22, 2002 09:31 AM
