Voltage regulator problems
Old May 4, 2016 | 11:53 PM
BULLS-N-BRONCS's Avatar
I am having voltage regulator issues on my 91. My Guage shows pegged @ 18 volts nearly all the time I am on the road. I have read in the stickies about converting to an internal regulator and would like to attempt it. Question is though what to do with the wire plug in from the external regulator? Does it just become not used at that point? Any help or answers are greatly appreciated.
Old May 5, 2016 | 09:19 AM
sooty's Avatar
have you checked volts at the battery? 18 would fry your lighting initially, with everything else following, 14.5 is max.
Old May 5, 2016 | 12:43 PM
j_martin's Avatar
I'm with sooty. 18V will burn things out, and blow the top off the battery. Hopefully it's just a bad indication (gauge). Check the actual voltage at the battery.
Old May 7, 2016 | 08:31 AM
BHD's Avatar
BHD
18V! Yikes! I swear by the regulators that are still available through Mopar. Those $19.95 units at places like SlaughtoZone are garbage.
Old May 7, 2016 | 01:43 PM
cougar's Avatar
This might help. https://www.dieseltruckresource.com/...-101-a-307266/
Old May 7, 2016 | 05:19 PM
peckens's Avatar
Put your regulator on a relay first. That should do the trick. External voltage regulator rewiring write up with a few pics - Dodge Cummins Diesel Forum
Old May 10, 2016 | 09:09 PM
Thanks for the info. It sure is nice to be able to ask questions and have responses to help a guy out. Thanks again...
Old May 10, 2016 | 10:08 PM
j_martin's Avatar
Just to clarify the comments. If either the ground or the feed (sample) voltage to the VR is weak, it will overcharge. A bypass ground lead to the body solves the ground issue. A relay feeding battery voltage driven by key on solves the sample voltage issue.
Old May 12, 2016 | 11:45 PM
Thanks for the info. I installed a relay as in the response from peckens. Solved my problem I believe.
Old May 14, 2016 | 11:20 AM
cougar's Avatar
Everything else is still running through a bad ignition switch. You should change it.
Old May 14, 2016 | 11:25 AM
j_martin's Avatar
Like ^^^^ says.
Old May 16, 2016 | 08:40 AM
Brian.B's Avatar
Could you just run a power wire from the battery to the voltage regulator just to test this and see if it's the problem before wording in a regulator.....
Old May 16, 2016 | 11:15 AM
cougar's Avatar
For those of us that have been at this for a long time, "hot wiring" a system to bypass suspected components including wiring and fuses is a standard troubleshooting technique. Don't do it without a wiring diagram though, you may fry something else.
TurboAZ
Aug 27, 2013 09:26 PM
shecom3
Jan 27, 2008 03:09 PM
Monty
Sep 9, 2003 08:04 PM
freeloader
Mar 28, 2003 09:00 PM
hellotbone
Oct 9, 2002 02:20 PM
