Vibration/drone at 70++
Old Mar 14, 2009 | 01:34 PM
DNRCustoms's Avatar
Ok...This drone/vibration issue is tappin me.. Under hard accel or light accel above 65 I get this haul from the underside towards the back it feels... Installed a new driveshaft, thought it was the answer, told myself it was the answer "cause I dropped like 400 buks" I have no rear blocks, angles are really good.. Flexplate is tight... Could it be my tires, the faster I go the worse it gets.. Tires came balanced from Four wheel parts... Like on cruise control at 70 it is there a little, go up a hill and it is really there, stomp on it and it won't go away untill I let off... I can't be getting that much axle wrap I don't think... Who's got some ideas form me.. Thanks
Old Mar 15, 2009 | 02:06 AM
Crazy Matt's Avatar
Is the wheelbase the same on both sides?
Old Mar 15, 2009 | 07:50 AM
RollinCoalSmoke's Avatar
My 92 would do the same thing. No noise no vibes till 70 plus, at 80 noise and bad vibes. Pulled diff cover 2 teeth missing and too much end play. Changed out ring, pinion, & bearings. Still had a very slight vibe above 70. Pulled drive shaft down completely & found 1 u-joint that was loose in the shaft, had shaft cut off and new end put on, fixed the prob completely. Good luck DNRCustoms you will find it.
Old Mar 15, 2009 | 09:40 AM
DNRCustoms's Avatar
never measured the wheelbase from side to side.. Hmm
Guess I could pull the diff cover and have a look.. Never had that apart on this one.. Thanks.
Old Mar 15, 2009 | 10:24 PM
DNRCustoms's Avatar
bump for a few more ideas..
Maybe take all 4 tires to see if they are good and balanced??
Old Mar 16, 2009 | 01:12 AM
Crazy Matt's Avatar
Both yokes tight? A t/c or axle bearing going bad? Pinion trying to point up to far under power?
Old Mar 16, 2009 | 12:20 PM
archer39's Avatar
what kinda of tires are you running? My old rig with goodyear MTR's would howl like crazy above 65 for some reason.
Old Mar 16, 2009 | 07:21 PM
DNRCustoms's Avatar
35x12.5 Micky Thompson ATZ's Load Range E.. Have the same style on my Mega and they make a little noise but not much...
Old Mar 16, 2009 | 09:39 PM
Didn't you put a new shiny driveshaft in your truck?
Old Mar 16, 2009 | 10:28 PM
DNRCustoms's Avatar
ya.. Read my original post!! Kinda thought that was the issue. But ends up being I just have a nice new shiny shaft now!!
Old May 17, 2009 | 08:36 PM
DNRCustoms's Avatar
Well, I'm about 95% sure it is the torque converter is the culprit for my annoying vibration/drone.. I was messing with it on the hwy this weekend and with the tc unlocked, I can get up to 80 and no drone or vib, once I lock the converter.. It all goes bad.. So.. what else can it be?? It has to be the tc.. I'm not a big tranny guy, but unlocked it is fine. Locked it isn't.. So must be the tc... Right??
Old May 17, 2009 | 09:52 PM
archer39's Avatar
sounds like my truck. Do you know if your trans had straight cut gears in it? Mine apparently does and i am told that is what is making the annoying looping/drone sound. I talked to Dave at Goerend for a few hours trying to figure it out and took the truck to an Goerend installer and i am told its normal for the straight cut gears.
I am working on a good sound deadening solution for the cab to help block it out.
Old May 18, 2009 | 07:07 AM
DNRCustoms's Avatar
so, yours only does it when locked up say 65 mph and up?? If it were gears you think it would happen locked or not. I have my floor insulated pretty good and it still drives me nuts.. I'm gonna go talk to the local trans guy. See what he says. I'll ask about the straight cut gears. If that the case, can it be changed without to much$$$ involved.
Old May 18, 2009 | 08:35 PM
schamran's Avatar
Is it possible to swap in a G-56 or a NV5600? That's what I would do, but only because I am a manual guy. Built autos are pretty fun though.
Old May 19, 2009 | 05:14 PM
archer39's Avatar
on my truck its still there when unlock just not as noticalble. Since your truck is insulated good you may only hear it when it is at its loudest. The back of my cab is completley exposed so it really amplifies the sound. The OD section must be pulled to change them out.
grey ghost
Mar 16, 2010 10:28 PM
dodgedsl03
Jan 18, 2007 10:08 PM
04DieselRamN
Mar 18, 2004 09:28 PM
cummins24
Jan 29, 2003 05:47 AM
