Vent tube leakage
Old Dec 17, 2008 | 12:55 PM
pokeypennell's Avatar
Vent tube leakage
On my 1990, it seems like theres a lot of fluid, I dont know what it is that drips from the plastic tube near the oil pan. Its on the driver side of the engine compartment. I think it is a vent tube?? Is this normal?? It seems to be running fine.
Old Dec 17, 2008 | 07:22 PM
That is the crankcase vent. Some oil will drip from there when you park the truck. As long as it's just a couple drips and not a puddle it's normal and nothing to be concerned about.
Old Dec 17, 2008 | 11:37 PM
roxxx's Avatar
This is the fancy fix ... But if your drive way or neighbors complain
http://www.peakdieselperformance.com...41/6179762.htm
My truck has a few leaks but that one always freaks me out after a hard run
Old Dec 18, 2008 | 08:53 AM
DHT's Avatar
DHT
Breather Tube
Has anyone ever used one of these and if so how do they work?
Old Dec 18, 2008 | 10:18 AM
Ace's Avatar
Ace
Here's the fix for those on a tight budget:
http://stuff.is-a-geek.net/PhotoAlbu...cs/CTD_112.jpg
Old Dec 18, 2008 | 10:51 AM
roxxx's Avatar
Lol here is what i was planning on using just to friggin cold out to do it
Attachment 25270
Old Dec 26, 2008 | 10:16 AM
i figured it out, I think that I overfilled the oil when i changed it. Its all set now. Now my lift pump decided that it wants to leak, so i ordered a new one before it completly dies!
Nick
Old Dec 26, 2008 | 02:04 PM
bigragu's Avatar
lo and behold, I actually made one sorta like the aftermarket, pricey item like the one pictured above a long time ago. Got tired of the drip on the driveway. Mine was inexpensive, but fully functional and clean looking. I bought pvc sprinkler fittings, brass fittings, and hose to make:
1.(1) 2"x2"x2" tee (all slip/glue on ends)
2. (1) 3/4" female thread to 2" slip bushing
3. (1) 1" female thread to 2" slip bushing
4. (1) 2" slip to 1/4" female thread bushing
5. 1/4" male thread petcock drain like the drain for your radiator. This threads onto piece number 4, and #4 will glue on to the tee portion of the tee fitting
6. 3/4" barbed coupling to tie into existing vent tube
7. about 3' of 3/4" oil resistant hose and 12" of 1" oil resistant hose
8. (1) 3/4" male thread to 3/4" barbed end (brass or plastic)
9. (1) 1" male thread to 1" barbed fitting (brass or plastic)
Add piece#6 to vent tube, tie in 3' of 3/4" tubing to extend vent tube into piece #8 which is connected to piece #2, which was glued into straight portion of tee fitting. The other end of the straight portion of the tee will get piece #3 glued on and piece#9 threaded on. From there push on the 12" of 1" hose. The tee portion of the tee fitting will point downwards, which catches the oil and holds it. You have to once in a while unscrew the petcock fitting and let the oil drain into a container. I no longer have an oily mess blowing towards the rearward parts of the truck, and driveway is clean. All I see coming out of the 1" hose is vapor/blowby gases. Sorry no pics. I mounted the contraption to the inside frame rail, directly under the middle part of the drivers side door. I used (2) 3" hose clamps screwed into the frame, and tightened the clamps around the tee fitting.
Dean Snow
Sep 21, 2007 01:18 PM
drew03
Sep 2, 2005 10:45 AM
wood_n_soldier
Jun 9, 2004 08:51 PM
ZACSP
Mar 24, 2004 03:53 PM
hellotbone
May 8, 2003 02:46 PM
