VE pump problems....Help please.....
Old Sep 14, 2011 | 04:53 PM
DodgeFreak's Avatar
Okay so i dove into my brothers ve pump and i have it tore down to support ring and the two bolts that hold it on striped out on me for some stupid reason....now what do i do to get it apart?????
Old Sep 14, 2011 | 05:05 PM
DodgeFreak's Avatar
Never mind i finally got them one came out after i drove the next size bigger torx in it and the other one i knocked it loose with a chisel (with out touching the case or the support ring) now the question is where do i find two more screws like that??? Thanks for your help.
Old Sep 14, 2011 | 07:21 PM
BearKiller's Avatar
ALWAYS use PLENTY of anti-sieze on any threaded fastener that does not thread directly into the "wet" part of the pump.
The bolts are steel; the pump-case is aluminum; no anti-sieze is just asking for trouble.
A decent hardware store ?may? be able to fix you up with the screws.
If not, then McMaster-CARR should have something that will work.
Old Sep 14, 2011 | 08:33 PM
DodgeFreak's Avatar
lol don't have to tell me about using anti sieze i use that stuff all the time need to tell bosch about it lol. thats where i was thinking about looking.
Old Sep 19, 2011 | 08:56 PM
DodgeFreak's Avatar
alright so i have the pump back together found screws that would work and then i realized that when i was cleaning the afc housing i set the breather on the coffee table and i'm pretty sure my 2year old son took off with it....so my question is what can i use in its place if i don't find it?
Old Sep 19, 2011 | 09:12 PM
DodgeFreak's Avatar
also forgot to add when i was cleaning parts i came across this....should i replace it or will it be okay?? its the only one with a mark i can catch my finger nail on it....its one of the top delivery valves so i can swap it if i can find one....
Attached Thumbnails VE pump problems....Help please.....-310538_10150379378030917_500790916_10029355_2135659533_n.jpg
Old Sep 20, 2011 | 11:28 AM
DodgeFreak's Avatar
any thoughts????
Old Sep 20, 2011 | 11:51 AM
I did not dis-assemble my delivery valves. So I'm not exactly sure what I'm looking at. Is there any info in the sticky about the condition of the parts within the delivery valves, and when/if they should be replaced.
Old Sep 20, 2011 | 12:01 PM
DodgeFreak's Avatar
its the part closest to the lines, robbed a picture from the sticky. not even sure how the mark got on there as the inside is smooth.....also is there any aftermarket dv or where can i pick up some stock ones with out costing an arm and a leg....
DJ Turbo.
Oct 13, 2011 09:11 PM
DHT
Apr 2, 2010 07:12 AM
smoky beast
Apr 22, 2008 07:24 AM
SuperiorRam
Mar 15, 2007 03:10 AM
MoparRiggan
Jan 17, 2006 12:43 PM
