VE pump, advanced level
Old Oct 29, 2009 | 11:07 AM
  #76
ZSkibo's Avatar
yeah but to my knowledge nobody has gotten the two to work together without failure in dramatic fashion. What specifically breaks and why is unknown to me.
Old Oct 29, 2009 | 11:28 PM
  #77
dieseldawg604's Avatar
Originally Posted by vic340
14mm head and rotor and 4 mm cam plate
kaaaaboooom!!!!
Old Nov 10, 2009 | 10:24 PM
  #78
dragrdan's Avatar
http://1stgen.org/viewtopic.php?t=63...asc&highlight=
Old Nov 11, 2009 | 12:27 AM
  #79
Lucas1's Avatar
dragrdan http://1stgen.org/viewtopic.php?t=63...s=0&postorder= asc&highlight=
wow
i wouldnt consider it....p-pumpin would cost less and your reliable
Old Dec 20, 2010 | 08:56 PM
  #80
Alwaysworking's Avatar
alwaysonDTR
who thinks, larger passages in every place you can get them would help?
what about modifying the fuel control collar so it won't block the spill way?
opening up dv passages?
I've got some time now
Old Dec 21, 2010 | 12:05 AM
  #81
jimbo486's Avatar
If the spill port in the plunger is exposed, fuel isn't sent through the delivery valves, then to the injectors. It's spilled out in the case. It's how the governor "defuels."
Old Dec 21, 2010 | 08:31 PM
  #82
alwaysonDTR
what i would like to try and figure out how to get ride of runaway issues...
Old Dec 22, 2010 | 01:20 PM
  #83
unixcowboy's Avatar
That's been a problem with diesels since waayyy back when I was young.
I've heard of some of the old Macks sucking oil out of the pan past the rings and taking off .....Only way to stop them was to put it in 5th, let out on the clutch and climb on the binders with both feet. IF it happened while you were on the road ----- bend over and kiss your behind goodbye ...Only thing that would stop them was a VERY LARGE tree or a concrete bridge support.
Old Dec 22, 2010 | 08:23 PM
  #84
BC847's Avatar
1st Generation Admin
I just got me a good "205" core to play with.
Old Dec 22, 2010 | 08:47 PM
  #85
92smokin blacky's Avatar
I just bought my buddies pump that needed resealed, I have been studyin up and I'm gonna tear it apart to see how it works for myself. I may have an idea but not sure if it'll end up happening or not
Old Dec 22, 2010 | 09:24 PM
  #86
ChrisLib's Avatar
Is there any significance to it being a 205? And where does one look to find these elusive secret code #`s?
Old Dec 23, 2010 | 10:17 AM
  #87
jbawden's Avatar
How about the clutch pedal?
Old Dec 23, 2010 | 11:40 AM
  #88
dieselJon's Avatar
92Smokin and BC847.
Things to do/think about in the VE. The vane pump can have more/bigger vanes. The inlet passages and return passages can be enlarged and the return regulated by a outside regulator thus giving you greater control over internal pressures and return flow (ie cooling factor...) Also, if you can find a way to make a larger delivery valve holder thus creating more flow through the delivery valves (also aftermarket support of adding this and creating different delivery valves).
If you can create a high FLOW of fuel (in and out to cool), with the pressures at reasonable levels, coupled with a few extra pumps, I really think a 14mm H&R with a 3.2-3.7mm cam lift will be able to spin 4k rpms.
duallybuster350
Mar 5, 2010 07:18 PM
ADMOPARMAN
Mar 9, 2007 06:43 PM
G1625S
Nov 5, 2005 01:18 PM
silverbullet02
Sep 23, 2005 04:09 PM
teckert
Jun 9, 2004 12:34 PM
