VE pump, advanced level
Old Mar 11, 2008 | 01:49 PM
  #46
bloodhound51's Avatar
dang those are extremely tight tolerences.
Maybe some 304 stainless, but thats hard on the CNC its got a whole lot better thermal coefficient then aluminium though. I wonder if they can bond those "apticote" coatings to stainless steel yet. I tell ya KTA did his homework on that setup.
Old Mar 16, 2008 | 10:36 PM
  #47
daking's Avatar
any luck on the cam plates Jon
Old Mar 17, 2008 | 11:08 AM
  #48
Alec's Avatar
Good info, and good work!
It seems to me that going to a larger plunger is better than going to a higher lift cam. The additional drive forces are the same for the same flow per angle of revolution, the cams are actually loaded less the more shallow they are, and the acceleration of the moving mass is less with the bigger plunger. That assumes that you can get the fuel you want with the 14mm head alone.
I had thought about trying to introduce regulated high pressure fuel into the housing through the return port -- it looked as though it would be pretty easy to do, and would keep timing and fuel supply volume maxxed. I don't run high rpm high hp, though, so it is not a mod I pursued.
Has anyone hooked up a case pressure monitor and logged pressure vs rpm vs hp?
BTW, I have a pump with the "half" AFC lever in it. Number on pump is:0 460 425 148 FWIW. Supposed to be from a 6bt in a 'dozer. Do we have an idea of how many different AFC levers & pins Bosch produced?
If any info from one of my pumps would be useful, please let me know.
Alec
Old Mar 17, 2008 | 03:31 PM
  #49
dieselJon's Avatar
No Daking. My problem is finding a used IP as I do not want mine to be messed up. But when I find it, in 24 hours I will be in the shop.
And yes, he says he can make them, just needs either the plans (or blueprints) or the actual piece itself. I would like a spare IP so not only do I have the camplate BUT I have a IP that I can break
Jon
Old Mar 17, 2008 | 07:39 PM
  #50
daking's Avatar
okay jon, theres a guy on here by the name of ford69557ci and he has a 4mm and 4.5mm camplate, i tryed to get the BPs but the shop dont want to let it go, wonder why,
and for the rest of you you need to get on 1stgen.org and browse the threads, because your 4 months behind
feeding the case with an eletric pump is a waste of time because the min case pressure is 75psi and max is 275psi depends on rpms and pressure regulator, you have to feed the regular intake with 45psi to 60psi and that were you get the power, tryed and proven,
besides the 14mm head you cant make any more desent power unless you get a 4mm cam plate, you can do the dv's and pickup an extra 10cc = 20hp
the highest flowin pump so far is 520cc out of 6x20's injectors
Old Mar 18, 2008 | 03:12 PM
  #51
dieselJon's Avatar
Yep, I am on 1stgen.org. Go by oldestof11 there. I was just when ford said he was flowing 520cc outta 6x20's. Folks thats 2 hp for every cc. But alas, the front seal kept blowing. I think he needs volume and not pressure.
Jon
Old Mar 18, 2008 | 05:10 PM
  #52
daking's Avatar
h hey Jon
the thing is he "says" that he was flowin that much fuel,
if tis true its good for 1040hp, if he can burn it, add some nitrous and we got our selfs a 1400hp ve pumped cummins,
and regarding the seal blow out, thats why i got biuld special made high pressure seals, its goin in the pump tomorrow, cant wait!!!!!
Old May 11, 2008 | 02:40 PM
  #53
dieselJon's Avatar
Ok, I finally got a call about my pump that I bought. I bought one about 3-4 weeks ago and the guy sent it by USPS Priority. Well he called yesterday and finally tracked it down to where it ended up. It is sitting in Rockford (45 mins away, USPS hub there) with Hazardous Material building. Evidently they smelled something (Ok, how did Rockford catch it and not somewheres up in MN?) and it is in a nice sized box and they put it on hold! Dont bother calling me guys, we did the leg work for you. Anyhoo, come the end of the week, I should have that puppy tore apart! WOOT!
Old May 11, 2008 | 03:21 PM
  #54
daking's Avatar
i was able to get rocken tech to send me some so i three of the 4mms
but i would like to see what you can come up with
Old May 13, 2008 | 08:38 PM
  #55
mhuppertz's Avatar
Originally Posted by daking
h hey Jon
Did you get this pump on yet?
Old Sep 30, 2008 | 06:51 PM
  #56
vic340's Avatar
im in front of the computer right now in bosch ESI SHOOT ME SOME NUMBERS
Old Sep 30, 2008 | 06:53 PM
  #57
vic340's Avatar
I have not been able to find a 14mm head and rotor for a VE only 13mm plungers for a P-pump. And there is a 14mm P&b for p-pump...
Old Sep 30, 2008 | 08:22 PM
  #58
you have to go on 1stgen.org and Priveate Message KTA about a 14mm pump
Old Oct 1, 2008 | 10:22 AM
  #59
vic340's Avatar
I think that the 14 mm head is a china made head or not available in the states...
Old Oct 1, 2008 | 11:20 AM
  #60
JAyers's Avatar
dude here ya go to http://rocken-tech.com/RotorHeads.html
All you have to do is scroll down and where it says Special 14mm rotor head for VE pump. Thats the one you want.
