Ve pump
Ve pump
I just did the piston pump upgrade in my93 I had my afc diaphragm off and fuel pump out with it open to have wd40 in it to loosen the cross pin. When I used lift pump to bleed air I noticed bubbles in the afc come out is that a bad thing or not?
Did the small pin pop too far into the afc housing? It most likely might with the main fuel pin out. I would put the fuel pin back in place and watch for more bubbles, if it does leak then you probably need a new O0ring on that small pin.
Puke
05-22-2003 12:18 AM
amartinson
0
05-04-2003 01:55 PM
TPilaske
16
11-22-2002 08:15 PM
Haulin_in_Dixie
47
11-17-2002 09:30 PM
