ve pump
Old Dec 27, 2017 | 02:09 PM
kctms's Avatar
ve pump
i have a 1989 dodge cummins when i bought it it idle at 1300 rpm and still does how can i idle it down tryed idel screw and a 1/4 turn out on power screw
Old Dec 27, 2017 | 02:14 PM
Have you disconnected the throttle linkage when adjusting the idle? Perhaps it's set too tight and not allowing the throttle position to drop back to it's proper resting spot.
Old Dec 27, 2017 | 02:27 PM
kctms's Avatar
yes on hooked throttle rod
Old Dec 27, 2017 | 02:52 PM
kctms's Avatar
problem seems to be in pump
Old Dec 27, 2017 | 02:54 PM
Has someone been inside the pump for any reason? Most likely it's a throttle indexing problem then.
Old Dec 27, 2017 | 02:56 PM
kctms's Avatar
not that i know of arm does not touch idle screw.
Old Dec 27, 2017 | 03:38 PM
Can you take a snapshot of it ?
You are looking at the one in the back near the head, right ? Circled in red here.
Old Dec 27, 2017 | 06:06 PM
kctms's Avatar
Yes circled in red.
Old Dec 27, 2017 | 06:25 PM
Is there a return spring on the throttle lever? With the throttle linkage disconnected can you push the throttle lever back against the stop?
Old Dec 27, 2017 | 06:42 PM
kctms's Avatar
Yes their is a spring and it is working when you move the screw idle dose not change and throttle will stop hitting linkage if you turn it far enough
Old Dec 27, 2017 | 07:12 PM
Sounds like it may be an internal issue, poor indexing on the throttle lever, or maybe the gov spring was installed incorrectly, or other internal issues?
Old Dec 28, 2017 | 05:33 AM
kctms's Avatar
how do you check indexing, thanks
powerwagon440
May 25, 2003 02:31 PM
Puke
May 22, 2003 12:18 AM
amartinson
0
May 4, 2003 01:55 PM
TPilaske
16
Nov 22, 2002 08:15 PM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
