Valve adjustment
Old Nov 29, 2006 | 04:49 PM
ixx's Avatar
ixx
Valve adjustment
What does adjusting the valves do? How can you tell if you need it? How is it done? I am totally clueless on this, I thought only motorcycles needed valve adjustments.
Old Nov 29, 2006 | 04:55 PM
The Cummins does not have hydraulic tappets, so the valve clearance must be set by hand. There has to be some clearance in the valvetrain or you will burn a valve, but too much clearance will cause parts to get pounded to death. The usual clue to needing a valve adjustment is that you can hear the valvetrain clattering as you roll down a hill. Cummins says to do it every 25k.
You can increase top end performance by setting them a little tighter than spec, this increases the effective duration of the cam.
There's info in the sticky about how to do it, so I won't get into that here.
Old Nov 29, 2006 | 04:57 PM
ixx's Avatar
ixx
Thanks. Sounds like I need to give it a look.
Fishbait
Nov 23, 2009 11:21 AM
ConnerCop
May 5, 2009 07:48 AM
dhughe2
13
Dec 6, 2006 07:40 AM
bulthisl
Mar 22, 2003 07:01 AM
blackboat
Nov 8, 2002 06:32 PM
