Vacuum Pumps Wear?
Old Jan 15, 2014 | 12:23 PM
mhuppertz's Avatar
Vacuum Pumps Wear?
My '93 has the vane style pump and it seems weak.
Has anyone had one wear out?
Old Jan 16, 2014 | 09:44 AM
sooty's Avatar
my older dual diaphragm lost one di' and went down 10hg's, making the brake booster less efficient, check your vacuum at the pump, also pinch off the booster to make sure its not leaking, if the pump is weak, they are rebuildable, you want to see around 20hg's when running after warmed up.
Old Jan 17, 2014 | 08:07 AM
patdaly's Avatar
Well, Gould sells vanes and seals, so I would say there must be at least a few wearing out, otherwise he wouldn't bother.
Check them out, fixinrams.com
Old Jan 17, 2014 | 10:30 AM
Since these vacuum pumps are, as stated, vane pumps, there is always the possibility that the vanes have worn out. But I highly doubt it.
I'd order a reseal kit and toss it in. Once it's apart you'll know for sure if the vanes need replacing.
Old Jan 17, 2014 | 10:49 PM
winston76548's Avatar
got a '93 W250; had same problem - ordered seal kit from Cummins. Vane condition was not prominet: Cummins 6B5.9 motor.
pokeypennell
Jun 26, 2007 07:02 AM
mattme
Jan 31, 2007 06:26 AM
Ilikebikes
Dec 11, 2006 10:13 PM
Contractor
Jan 18, 2005 08:13 PM
Ggg
Dec 13, 2004 08:07 PM
