vac/ps leak
Old Jan 8, 2005 | 10:48 AM
rebal's Avatar
Angry vac/ps leak
is there a good cure for the leak from the vac/ps unit?
Old Jan 9, 2005 | 10:00 AM
DesertRat93's Avatar
I fixed my leaky vac/ps unit with new orings and seals in a kit that PDR sold me. Easy fix to do and no oil leaks since.
Old Jan 9, 2005 | 10:43 AM
rebal's Avatar
PDR ? sorry new
Old Jan 9, 2005 | 02:08 PM
frostie's Avatar
PDR is piers diesel, click on links up top and go to high performance.
I bought a seal and oring locally, it took some time to get.
The big oring is 57x59x2, it is metric, It cost me 40 cents. the seal, I cant remember, it was something like 26x36x7 dont quote me on that one, but it was about $5.
When you pull the powersteering pump, then pull the aluminium adapter that has 2 bolts holding it on, you can replace the seal on the bench that is in that piece, then the oring seals the adapter back to the vacuum pump.
Good luck
Old Jan 9, 2005 | 05:58 PM
rebal's Avatar
i put new seals in and O ring 250 miles later and its leaking
Common
Jun 25, 2008 06:59 PM
stationarycoppe
Jan 2, 2008 08:53 AM
jlarmour
0
Mar 17, 2007 02:57 PM
Dojman
Mar 30, 2004 07:38 PM
97Dually
Apr 15, 2003 11:16 PM
