Used flatbed help
Old Dec 16, 2013 | 04:45 PM
5090ss's Avatar
Used flatbed help
Hello,
I am needing to put a used flatbed on my 93 but donor Dodges are scarce here. I got it in my head that Chevy frame rail widths were the same as Dodge back then or was it Ford? Are these usually bolted down like on bigger trucks or will I need to make some weld on brackets? I will need to pull a gooseneck trailer. Thanks for any advice.
Old Dec 16, 2013 | 05:54 PM
simplysmn's Avatar
Chevy should be close and do yourself a favor and Trash the K&N filter before it Trashes your Motor .
Old Dec 16, 2013 | 06:01 PM
haultruck's Avatar
i cant tell ya widths, but after ya get your long rails the same width as your frame, set it down on your frame hump above your axle, then make sure the distance between your rails and your frame are the same front and back, then get some pieces of 4" wide by 5/16 or 3/8 thick channel, weld it to the rail on the flatbed, and then drill and bolt it to your frame. I use channel because it gives it strength from side to side as well. I also make it long enough to cover about 2/3 of the frame up and down so I can get two bolts in each piece. I use three pieces on each side, but two is probably enough. I haul a lot of weight. that's how 4 out of 5 of my flatbeds are done. I'll see if I can get a pic later.
Old Dec 16, 2013 | 06:21 PM
haultruck's Avatar
Attachment 42332
Old Dec 16, 2013 | 06:50 PM
samboats's Avatar
My 91 1 ton has a flat bed that has brackets that allow for the difference between the truck and bed frames width. The utility body I took off of it had the same setup. The 78 3/4 ton the flat bed came off of was also the same way. If that is confusing, all I'm saying is that the frame width and the bed width was not the same on any of it.
Old Dec 17, 2013 | 09:06 AM
mknittle's Avatar
I don"t know about the 90s but the 70s and 80s chevys are narrower by 4"
Old Dec 17, 2013 | 10:48 AM
gyman98's Avatar
These trucks are the same width:
1967-1996 Ford 1/2 Ton Trucks
1967-1998 Ford 3/4 and 1 Ton Trucks
1999-2010 Ford Cab & Chassis 34" Frame
1973-1987 Chevrolet/GMC 1/2, 3/4 and 1 Ton Trucks Long Bed
1988-2009 Chevrolet/GMC 1 Ton Cab & Chassis 34" Frame (without dual tanks)
Old Dec 17, 2013 | 11:20 AM
mknittle's Avatar
first gen Dodge frames are 38.125" outside to outside.
Nov 30, 2013 12:42 PM
hitcb1789
May 25, 2010 09:10 AM
CMN_NOT_STROKN
Mar 1, 2003 08:45 AM
Dec 12, 2002 06:44 AM
35
Nov 8, 2002 08:36 AM
