Usable power upgrades
Old Oct 5, 2009 | 07:44 PM
moldy4640's Avatar
I have a '92 w250 auto and I quite often am pulling (10-15k). What can I do to get some more power? Not crazy, but enough to make it pull a little better. Thanks.
Old Oct 5, 2009 | 07:54 PM
stinkindiesel's Avatar
First step (and it's a biggie) is to fill in your sig so we know what you've got and what you've done. Then the rest of us will get to work with horribly impractical advice.
Old Oct 5, 2009 | 08:02 PM
Free89W350's Avatar
1st thing is get guages aka pyro, fuel psi, boost and trans temp. Then change your exhaust housing to a smaller more practical towing housing then some mild pump tuning and a 3k gov. spring. You may also want to get a tighter torque converter.
Old Oct 5, 2009 | 08:06 PM
moldy4640's Avatar
I got a pic to appear but no sig for some reason. 92 w250 with duals, auto, bone stock. Missing anything?
Old Oct 5, 2009 | 08:07 PM
archer39's Avatar
^^^yep and then after that you will want some more air to keep things cool.
Old Oct 5, 2009 | 08:13 PM
The_Head's Avatar
If you're not looking to do anything crazy, replace the stock convertor. That will help alot.
Old Oct 5, 2009 | 08:19 PM
Twisted Inc.'s Avatar
i highly recommend doing a little pump tampering, hauling is the main thing i use my truck for and often pull heavy loads like you do...the power turning a few screws gave me was amazing although you definitly need a pyrometer if your going to pull with a cranked up pump.....just my 2cents
Old Oct 5, 2009 | 08:51 PM
peobryant's Avatar
Gauges
Bosh 190 injectors
Piston Lift Pump (low psi)
4" exhaust
1/8" bump timing
Either an HX40 or HX35
Goerend converter
That list is in no particular order (gauges and converter should be first though) but it should give you pretty good ideas. For some clarification, the bosh 190's are actually smaller than your stock I/C injectors, but they atomize the fuel better, so they will make more power and give you better mileage. Also, on turbo. the HX35 would probably be enough for you, but the HX40 will flow more air. If you can spend the money, I'd go for an HX40 (you can find them used for around $500,) if not, an HX35 would be good.
Old Oct 5, 2009 | 08:53 PM
correct me if im wrong but won't bumping the timing seriously raise egt's?
Old Oct 5, 2009 | 09:02 PM
14racing's Avatar
It's supposed to lower egt's but thats a questionable subject. I bumped mine and really didn't see much of a change in egt's.
Old Oct 5, 2009 | 11:43 PM
JQmile's Avatar
Start out with gauges and pump fiddling. Stock converters can handle more than you think.
Bobcat698
15
May 19, 2010 04:50 PM
Diesel97
15
Jun 30, 2007 08:34 AM
rbrettctd
May 24, 2007 03:59 AM
pullin hard
May 28, 2006 07:45 AM
Ripper406
Jun 10, 2005 12:48 AM
