Sponsored by:
Sponsored by: CARiD
Wastegate, repairable? Usable?
Old May 22, 2007 | 03:26 PM
rbrettctd's Avatar
Is this repairable or usable as is?
Old May 22, 2007 | 08:56 PM
Troutstrannysvc's Avatar
Depends if the diafram inside is broke or not.
Hook it up to a vacume and see if it works?
Old May 23, 2007 | 12:59 PM
rbrettctd's Avatar
How does that show? Could I use an A/C vacuum pump? Then what does it do if it is good or no good?
Old May 23, 2007 | 03:22 PM
logskidder's Avatar
Just pump 40 psi of compressed air to it......see if the rod moves.
Old May 23, 2007 | 03:27 PM
Common's Avatar
A $25 boost elbow does the same thing...
Old May 23, 2007 | 04:22 PM
Uh, no it doesn't. A boost elbow is just a leak. It lets the boost spike but it will eventually drop down to the wastegate. A manual boost controller works well, though.
Old May 23, 2007 | 09:59 PM
Common's Avatar
I totally knew that
Old May 24, 2007 | 03:59 AM
Dodgezilla's Avatar
Mine looks like that after trying to force the turbo on the studs with the wastegate hitting the motormount. It damaged something inside because now the WG is stuck open and I had to clamp off the hose to keep from losing all my boost.....
Chrisreyn
Oct 9, 2010 01:44 AM
Bobcat698
15
May 19, 2010 04:50 PM
pullin hard
May 28, 2006 07:45 AM
Ripper406
Jun 10, 2005 12:48 AM
Lil Dog
Feb 11, 2003 04:08 PM
